Old January 9th 2010, 14:22
spooky spooky is offline
Question 944 alum backing plates - leaks/slinger
Hi guys,
I'm using machine aluminium 944 backing plate. Obviously with this setup there is no oil slinger.
Does anyone have else have this setup? Any issues with leaks?
I'm wondering if I should drill a hole in the backing plate just in case.
Thanks!
Spooky
Old January 20th 2010, 06:54
kombi211 kombi211 is offline
there should be no problems with that backing plates the way they are. there is nothing there to leak. the only vw that had a oil slinger that i no of where the swing axle one. being there was gear lube in the axle tubes to lube the bearings
Old January 20th 2010, 07:07
Sorry, I should of clarified, Its on a swing axle
Tags
944 oil slinger brake
