Old November 26th 2002, 07:24
Andy White's Avatar
Andy White Andy White is offline
Re-applying the Porsche enscription.
Hi everyone,
I am planning to strip and rebuild my 944 turbo calipers. I will have them media blasted and powder coated, but I'd like to keep the Porsche enscription. Short of masking off the area does anyone have any ideas on how to re-apply the logo?
I have already contemplated using stickers and even thought about having a rubber stamp made to apply some heat resistant paint or 2K. Any other ideas or knowledge on the subject would be greatly appreciated.
Regards,
Andy.
'55 oval GL
944T Calipers and discs front & rear.
17" Turbo rims 205/40 front, 215/45
rears
230BHP TIV fuel injected.
IRS+Berg 5 speed box.
Build in progress.
Old November 26th 2002, 17:42
Jim Andritsakos's Avatar
Hello Andy,
Easy solution : buy decals with the "Porsche" logo after you have powdercoat you calipers apply them and after that apply some light coats of clear coat.
Rgds,
Jim Andritsakos
74 1303 GL (project)
89 T3 Syncro panel
Old November 26th 2002, 18:42
Flintstones's Avatar
Flintstones Flintstones is offline
Do the calipers have the porsche logo on them already? and is it a rasied logo? if it is, when you get them powder coated, tell the person that is spraying the powder to wipe the powder off the logo.
Cheers
Old November 27th 2002, 02:20
Andy White's Avatar
Hi Jim,
I thought about that, but clearcoat usually tarnishes and turns a yellow colour under severe heat. That even seems to be true with 2k paint as I found out when I painted my engine tinware pearl white on my last bug. Under close inspection you can see that the Porsche enscription from the factory seems to be painted. Any ideas on how they create this at the factory?
Cheers,
Andy.
'55 oval GL
rears
Build in progress.
Old November 27th 2002, 04:03
Hello Andy,
Factory using a quite complicated method to do that:
Before they apply the final color of the caliper (ex yellow)
they apply a white (or black) coat in the front of the caliper.after that they apply a sticker with the "Porsche",then the caliper(s) sprayed with the final color.After that the sticker was removed and here you are !
Rgds,
Jim Andritsakos
89 T3 Syncro panel
Old November 27th 2002, 09:08
Andy White's Avatar
Cheers for the info Jim.
Sounds like a lot of bother. I think I'll have a Porsche stamp made up and try to stamp the white on top of the base colour in 2k to see if it works. Failing that your idea of using decals and a clearcoat sounds easier than the factory method.
Thanks again,
Andy.
'55 oval GL
rears
Build in progress.
Old November 27th 2002, 10:24
When i bought my new Boxster rears they were only a crappy anodised black. I painted them and got a little old lady i know who paints clock faces the repaint the logo. I just used odinary enamel as brakes dont get as hot as you would think. I found a Porsche font on the net somewhere so I was able to give here pattern to go off.
Steve C
Old November 27th 2002, 11:59
Pillow's Avatar
Pillow Pillow is offline
Check this out:
http://www.pelicanparts.com/techarti...edCaliper2.htm
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old November 30th 2002, 02:28
Andy White's Avatar
Hi Adrian,
Thanks for the link, it was exactly what I was looking for. I'll have some masks made and see how it goes. Just need to decide which colour to paint them now
Regards,
Andy.
'55 oval GL
rears
Build in progress.
Old February 24th 2003, 17:01
And here's the Porsche font. Its a TTF for Windows based computers.
Old February 25th 2003, 02:47
Andy White's Avatar
Thanks Sandeep,
I work on a mac, so I ended up redrawing it in illustrator. If anyone needs access to a clean Porsche logo don't hesitate to ask.
Cheers,
Andy.
'55 oval GL
rears
Build in progress.
Old March 4th 2003, 05:52
hot66's Avatar
hot66 hot66 is offline
andy, did you end up getting a stencil made for the calipers? I'm looking for a similar thing for my calipers
project in progress
Old March 4th 2003, 06:34
Superman
www.europdr.com/caliperstencil.htm
Old March 4th 2003, 06:51
hot66's Avatar
thanks
I have just purchased some stickers from a porsche specialist in the UK, they have used these stickers for years now with no problems, so I thought I'd give them a try
project in progress
