Old May 5th 2009, 01:12
Veedub Veedub is offline
The new plan
while the site was down I had decided to sell my 13x5.5's and 14x7's along with my 5zigen wheels.Well now I have my eyes on a set of wheels that I really like.Problem is will they work?
There 15x7 with a +37et. I want to get dropped spindles and run the stock drums, not going with discs.
Will I have any interference in the front suspension of my bug, its a 72 standard.I was thinking of just getting wider fenders up front to go with the rear.The rears are 15x8 with a -27et.I'll deff need wide fenders in the rear.
Old January 27th 2010, 18:31
Well, we tried them on my bug , removing the vw wheel on it.Just leaning it on the bugs front drum.I didnt like the look, an there was no room with turning.Then we put a 13x5.5" wheel on it an i lived the look.So now im going 13x5.5's up front and 14x7's.M question now is on some sites they give a big pop up warning about brake failure.Should i really worry?I'm thinking of running 165/65 or 155/70/13's up front and a 225/65/14 in rear.I like the more meat in the rear look.I know its not GL though or cal look either
Old January 27th 2010, 21:35
Most likely you wont be running the brakes hard enough to worry about failure.
Old January 27th 2010, 23:18
What do you mean?That a bad thing?
Old January 28th 2010, 00:09
chug_A_bug's Avatar
if your not tracking or Diving into Corners hard you will be fine with the Stock drums...
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
Old January 28th 2010, 17:53
ok cool.
Old January 28th 2010, 19:31
What he said
Old February 3rd 2010, 02:52
Well I have been tire searching and came up with 3 options, not sure which to go with.I wont go on highways that need to do 60mph so I dont think I'll have and issue with the gears changing.
Option 1: 175/50/13 in front
205/50/14 in rear
Option 2: 175/60/13 in front
205/60/14 in rear
Option 3: 185/60/13 in front
235/60/14 in rear
Anyone got any opinions on which to go with
Old February 3rd 2010, 05:08
evilC's Avatar
evilC evilC is offline
As I see it:
1) Significant lowering - Speedo error 21% (read high), undergeared by 12 1/2%
2) Medium lowering - Speedo error 16%, undergeared 6%
3) Moderate lowering, nose down, rear tyres too wide - Speedo error 14%, standard gearing.
Unless you raise 1st/2nd gear with option 1 that vehicle will be a PIA as it will be effectively have only 3 gears, 1st being a granny low gear. 2nd gear will be a little too high to take off comfortably although reasonably possible. Option 3 provides too wide a tyre on the rear unless you've got in excess of 100bhp. Of the 3, option 2 is the least problematic although like the other two you will need to correct the speedo.
Old February 3rd 2010, 17:26
Option 1 I didnt realize the 175/50's are 19.5" tall, so those are out and from the sounds, if gearing is that bad then thats a no no. Option 2 or 3 is what Im thinking. For option 2 I did find a 215 and a 225/60 in a 14". I like the nose down look, but Im still deciding, once my tax return comes then I'll buy the option that i get.
Old February 12th 2010, 18:50
chug_A_bug's Avatar
try these guys for the Spoiler...
http://www.kerscher-tuning.de/kaefer...pe2=Stoßfänger / Spoiler / Motor - Kofferhauben
74 Std. GL
08 Vw rabbit
18 WR250R
Old February 14th 2010, 00:40
Thanks for the info on the spoiler, and shipping from that place would be killer to be sent to Florida.
I forgot I was in the wheel section, sorry
Old March 12th 2010, 00:22
My knock offs for my wheels came in.
The plan for the wheels is solid gloss black, no pinstripe on the lip, with chrome lug nuts and chrome knock off, with my own emblem, not sure what I'm going to create but was thinking of my own VW emblem.
Id make a GL emblem but I dont think my look is GL at all, or Cal look, at that.
The tires are Hankook Ventus HRII's in a 195/50/15 front and rear. Painting the lettering on the tires white also.
Old December 30th 2010, 01:49
The 8's are painted,knock offs are on with chrome lug nuts with raised white lettering. Looks pretty sweet to me although its not GL but oh well lol
I'll post pics later, also got a pretty sweet fiberglass hood too
I need a fat tire for the rear though, to fit the look.Im thinkin 205/60,215/60 or 225/60.I'm pretty sure I can fit those on a 8 spoke wheel.My dad says it looks like it would be a racecar lol
