Old May 11th 2009, 08:50
DWP DWP is offline
944 and CB brake bias question
Gotten to a point of total confusion Time to make a decision.
I am using a sandrail type frame to build a street Car.
1.7 porsche engine 944 rear brakes with single caliper.
CB performance front brakes, lowered spindle, ball joint.
CNC brake pedal assembly with bias adjuster bar.
I can drill the front drum for 5-130 stud pattern.
AS most if not all the weight is in the rear of the car any problems with this setup? My concern is too much brake in the back,
Dave
Old May 11th 2009, 12:05
evilC's Avatar
evilC evilC is offline
For a normal bug the front/rear bias is conveniently ~50/50. That also works well with the 944 setup front/rear with larger calipers at the back with around the same piston area as the front. For your application you are certainly going about it in the right way but there are a few unanswered questions:
1) What's the anticipated front/rear weight split?
2) What's the piston/disc (rotor) sizes of the CB fronts?
3) What m/c's are you going to use? - a good starting point is likely to be a pair of 19mm (0.750") units. With the bias adjuster you do have adjustability built in. If you run out of adjustment then its easy to swap in a different sized m/c for one of the lines without having to resort to different calipers that must be the final and most expensive alteration.
With your setup there are too many variables to give a difinitive answer but it should be too difficult to dial in the correct setup. Now if you had a dual m/c..................... (heaven help us!)
