Old June 4th 2010, 09:30
bluebonnet's Avatar
bluebonnet bluebonnet is offline
901 Conversion HELP
I cannot get my bug flywheel to fit in the bell housing of my 901 transmission. Anyone ever had this problem. I am not sure if it is a diameter issue or there is something holding it out. HELP!!!
Keep Buggin
69 STD. 1776 CC
Old June 4th 2010, 22:28
Your leaving alot of info out. What year trans? You have a clutch and pressure plate on it? Pilot bearing good? Length of input shaft compared to bug trans? Clutch disc splines?
Old June 11th 2010, 20:52
bluebonnet's Avatar
Thanks, I got it. Thanks to the help of Chug-a-bug. The year Transmission I was using uses the same flywheel as the stock 12 volt beetle so I had to make a mounting plate for the tranny to get everything to fit. Rolling again.
Keep Buggin
69 STD. 1776 CC
Old June 11th 2010, 21:51
chug_A_bug's Avatar
No prob dude... that's what we are all here for is to help eachother out
now we just got some Fine tuning to do.
74 Std. GL
08 Vw rabbit
18 WR250R
07 Chevy 3500 Dually
