Old February 13th 2005, 20:38
yetibone's Avatar
yetibone yetibone is offline
Where I'm at so far...
A few pics of the 1303 pan and stuff
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 13th 2005, 20:42
yetibone's Avatar
Mo' pics...
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 13th 2005, 21:46
vujade's Avatar
vujade vujade is offline
looking good yeti
btw, what are those stabilizer bars that you welded on the the
lower control arms?
WinterJam 2010
Old February 13th 2005, 22:15
yetibone's Avatar
They're diagonal links with heim joints at the upper ends. They keep the horizontal control arms from having to rely on the sway bar to control caster, like a radius arm would.
They are only tacked on in the pics. I've made the pieces to box the whole arms in with, top and bottom. I'll weld them at work tomorrow.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old February 14th 2005, 05:18
Sure could have saved a bunch of time welding that 911 front end I have in place.
Looks good Joe, gonna have to come and see it soon.
63 356b time capsule
948 project
Old February 14th 2005, 06:50
A pre-964 front end is less high tech than a Mc Pherson 1303 front end
The extra control arms with heim joints look a lot like a set-up I saw many years ago on a german Kaefercup car..
Looks very good!
Walter
PS: Jurgen, did you ever come to informing about shipping costs of the 912E tach we talked about?
Old May 29th 2005, 18:51
yetibone's Avatar
Pics of my strut tower brace, and Kafer Cup brace pieces. Still haven't finished the bars for the cup brace, and still waiting for some 6" M12 bolts from McMaster to finish the tops of the rear shock towers.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old May 29th 2005, 18:54
yetibone's Avatar
couple mo' pics...
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old May 31st 2005, 15:04
yeti, what are you doing for bumpstops on the rear? i still have yet to do anything and need to. much more difficult with the body on though.
Old May 31st 2005, 18:24
yetibone's Avatar
Since I got early alloy arms, I made some from the leftovers of my sawed-off shorter front bumpstops.
Drilled a 1/4 inch hole 1/2 inch deep, tapped it to M8 1.25, stuffed the leftover washers from some stock 944 inner rear control arm bushings into those little rubber acordians, and bolted 'em down.
I know you have later alloy arms on yours, so the pedistal isn't there. Is there some way you could adapt swingaxle bumpstops to work on yours?
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 17th 2005, 20:41
yetibone's Avatar
The pan is done. I put the engine back on for some pics, and realized the drivetrain will need to tilt back an inch, or less to be right. I'll have to do that with the body on to find out exactly how far though...
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 17th 2005, 20:51
Schweeeeeet. A seeat and some controlls and it will be ready to put on the Dyno in Nov. :agree:
yetibone's Avatar
Here's the rear swaybar. Had to use one that was long enough to clear the crossmember, and make my own brackets, and clamps. The endlinks are like the front ones.
I have to do some clearance work at the endlinks before it's ready to go.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 17th 2005, 21:26
yetibone's Avatar
Here's my home made Kafer Cup brace.
The tubes are hollow T6 aluminum, except for the ends, which were solid T6 'till I turned them down to the tubing's inner diameter, and drilled and tapped them for the fork ends on a lathe. All the chassis connections, the fork ends, and the shock tower pieces are steel.
The front brace was made the same way, but it's all aluminum, 'cept the fork ends.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old July 17th 2005, 21:50
rustbucket's Avatar
That chassis looks totally sick. It'll be a blast on the track when it's done.
And I'm taking notes. I'd like to do a super next time around if I can't find a good T3.
It's YELLOW
Rolling on a daily basis.
