Old June 19th 2006, 22:35
56oval's Avatar
56oval 56oval is offline
my 56 money pit
the body have the channels removed and a metal bead instead of the plstic guard beading.
I,m using a 74 pan but removing the front and using a Mitshubishi L300 front end
this allows me to use the front disc & 7" wheels t comply with road laws in Victoria Australia it will be channelled 40mm higher to lower car and keep wheel geometry.
I,ll be welding in a complete 944 rear end 60mm higher for the same reasons as the front.
rear brakes honda NSX stud pattern allows better selection of wheels front the same stud pattern
gearbox porsche 915 .
wheels will be 18,s rear & 17,s front.
Old June 19th 2006, 22:45
56oval's Avatar
here is the body and more pics
I,llbe using 27mm diam 21" long torsin bars so I can move the gearbox forward 60mm.A brake pedalbox dual brake master cylinders ,hydraulic clutch and accelerator pedal.
Old June 20th 2006, 01:12
speedy's Avatar
speedy speedy is offline
wow looks like you will have your work cut out for the next few years keep us posted , looks like it is going to be really interesting
woop woop
67 2276 turbo
64 ghia 1776
zx7rr
Old June 20th 2006, 03:34
Definitely keep us updated on this one
What engine do you plan on running?
Rich
Old June 20th 2006, 03:53
Hi 56oval,
nice project.
Saw that you will be working with 915 gearbox. If you need short nose cone, front/rear mounting, axle flanges 100 mm,... ---> then have a look on www.bugat5speed.de
Martin Bott
Old June 20th 2006, 05:21
56oval's Avatar
bug@5speed
Martin is your web site in english yet I,ve logged on a few times.
Motor that is the question ej20,er33,13bt,type4 turbo or 2.7 ltr.
I,ll get the pan sorted first if I go with late jap the engineer wants a torsion test done .bought the honda nsx front brakes today .
