To Steve C
Hello Steve,
I am doing a 930 installation in a 1303 currently and as the bellhousing is identical to g-50 I would like to ask you what have you done about the rear trans mounts ? The oem beetle does not fit and required major welding to flatten the area any idea ??? Rgds, Jim Andritsakos
Jim Hunter 74 1303 (GL project) *SOLD* 73 1303 (GL project II) (VW T3s for sale.Panels, 2wd and Syncros) |
Hi,
if the bellhousing looks like the 915-bellhousing, then I can offer you the usage of my new laser cut steel traverse with 2 aluminium blocks that have the shape of the bellhousing. The traverse comes with 4 rubber blocks (2 for vertical movement and 2 for horizontal movement). Give me your mail-address and I´ll send you pictures of this part. Martin Bott Bug @ 5-Speed www.bugat5speed.de |
Im moving my motor forward 100 mm, so Im going to use the stock Subaru mounts and bolting them to a bracket on the frame horns. Im using the stock G50 front mount, a Berg style mount in the middle so that the box dosent drop down with the motor removed. Progress has been a bit slow, doing lots of work around the house. Steve
Hi steve, i wondered how you were getting on with the gearbox,
jon
woop woop 67 2276 turbo 64 ghia 1776 zx7rr |
I've done as much as can on the pan for the time being, I'm getting the body ready for paint now, I only have tiny garage as we live on the edge of a cliff. I have to leave the body and pan together for as long as I can. When the body comes off I can get in and do some of the welding that still needs to be done in hard to get at places. The shift lever is in, I need to muck around with the shift rod when the body is off and I can pull the box in & out easily. Thanks for asking, Steve
