Old August 7th 2002, 20:04
bugsoup bugsoup is offline
Rear torsion adjusters
Has anyone installed rear torsion adjusters that mount in the middle of the tube? I'd like to install one but I'm not sure whether it's worth the trouble. Also, If someone has done it already, it would be a perfect topic for a tech article when that gets up and running.
thanks
Scott
My Blog
Please help me get a minimac
Parts I Need
1965 Beetle "Gordie", 1956 GL Beetle
Old August 11th 2002, 04:34
Superman
In all my days I've never even heard of those
Old August 11th 2002, 09:23
vujade's Avatar
vujade vujade is offline
they are made by sway away...
WinterJam 2010
Old August 11th 2002, 10:05
I think they are made by SAW. There are a few places that sell them, but the adjusters are mostly used for offroaders who want to have more control of the ride height. I don't see why it wouldn't work to lower a road car . I'm considering these because I'm installing early aluminum (from an '86 944) semi trailing arms, but the SAW adjustable spring plates won't fit. The center mounted units are side to side adjustable so it won't be a compromise.
thanks
Scott
My Blog
Parts I Need
Old August 12th 2002, 07:56
bren's Avatar
bren bren is offline
heres a pic from the swayaway website:
"torsion bars. These units can be welded into a rear torsion housing or can be ordered with your new chassis. The removable adjusting arms are manufactured from alloy steel and are heat treated to full strength. Adjustment is as simple as turning a screw, one for each side allowing easy changes in ride height and cornering weights. These units are available in the strong standard design or the stronger King Kong racing version. Our 40 Tooth Torsion Center is designed for replacement of that
worn out stock center or can be used in new custom car construction where adjustability is not needed. Welds into place. "
