Old September 16th 2007, 11:23
Eatoniashoprat's Avatar
Gearing for subie
Hi, I've got my Ej20 turbo and its gonna be around 230hp in my '72 super. It will be running at full weight with subaru engine/rad. I'm getting a type 1 box built for it but I need to figure out which gear ratios to use. I'm thinking start with a 3.88 R/P and 4th gear to be around 0.82-0.89. With a 24" tire that will put me at 62mph at 2800-3000rpm. Now I have heard to just use the stock 1-3 with this setup but I have fears that first gear will be too low. Has anyone used this box with this setup on here and what works for you? Thanks
1302 EJ20 turbo
Old September 17th 2007, 03:45
Hi,
hope that you do not spend too much money on building the type 1 gearbox, cause it will probably break. The Subi Turbo gives a torque of more than 300 Nm and this is far too much for the type 1 tranny. We always use Porsche 915-gearboxes for the EJ 20T. Even the 901/914 will not stand the torque.
Porsche 901/914 won´t stand more than 270/280 Nm. The type 1 is much weaker than the 914.
Hope you choose the right way with investing.
Martin
Old September 17th 2007, 10:39
Originally Posted by Bugat5speed View Post
Hi,
Martin
Thanks Martin, There are many success stories using a type 1 box based on the type of driving I will be doing. There are type 1 boxes of similar spec to mine that run 11 sec. passes (fairly) consistently. My car won't be that fast or have the shock load of a dedicated drag car. With the right tire, clutch choice/management I think it should be okay. I agree that Porsche or a bus box would be the 'right' way, however I added it up and its not in my budget right now. I can get what I need out of a type 1 box for much less than a Porsche unit.
Now, how about those gear ratios? Even if I had a good first gear ratio I could split 2nd and 3rd since I think I have a good choice for 4th... Anyone?
1302 EJ20 turbo
