Old August 18th 2003, 13:59
kiwivw kiwivw is offline
Measuring Caliper Piston Size
Hi All,
When measuring caliper piston size is it the diameter of the piston itself (i.e. the part that actually touches the brake pad) or the diameter of the hole in the caliper (includes the piston seals and base)?
Cheers
Craig.
Old August 18th 2003, 16:44
bugsoup bugsoup is offline
I could be wrong, but since the seal actually helps transmit the pressure from the fluid to the piston, the measurement should be taken for the bore of the caliper. I assume you need the measurement to figure out forces and pressures so I would think this would be the most accurate way no matter what.
thanks
Scott
My Blog
Please help me get a minimac
Parts I Need
1965 Beetle "Gordie", 1956 GL Beetle
Old September 25th 2003, 23:29
Michael Ghia's Avatar
I've always measured the piston... I don't think that there is going to be 1mm difference between the piston and the bore but I could be wrong.
MG
