Old April 1st 2003, 00:10
airwerks airwerks is offline
Street Eliminators?
Getting ready to put my 2275 together, and trying to decide on heads. Cam is web 86b. Question is whether to buy the cb cnc 044's or run a set of ported street eliminators that I already have.
My biggest concern is cooling, less fins on the eliminators. Will doghouse(all german w/working t.stat) and remote oil cooler be enough? No heat exchangers, but still w/undertins.
Any experience with this kind of setup on the street would be appreciated, Trying to see if I have to buck up for the carbon fibre csp porsche kit $$$$ but
Old April 2nd 2003, 03:04
Someone here has to have run street elim's before???
Old April 4th 2003, 02:00
Carbon Joe's Avatar
I've had a set of SE heads on my engine (2110) for over ten years with no overheating problems what so ever. Last sunday it was 95 degrees here and my CR is just over 8.5 to 1, sure I have to run super but that's OK. I have an external oil cooler with a fan and all the stock cooling tin, even with the top down no problems.
Joe
79 1303 GL
carbonjoe@ca.rr.com
Old April 13th 2003, 17:58
factman factman is offline
if you want a fully streetable head that cools well and gives you gobs of airspeed and volume then go to aircooled.net on the web. the L6 head they have uses a CB 044 head that is ported and polished and polished chambers and the whole works for $800 a pair. i am getting the same engine you are with the 86B cam and you will make well over 200 horse with this setup. im only running 1.25 rockers but that cam also accepts 1.5 also. just make sure you have a tranny that will support all that power lol.
speed is fun. why can't cops understand lol.
'64 notch 2.5L T4
'70 bug 1776cc
