Old April 15th 2003, 20:36
NYBugman1972's Avatar
What year 944 Brakes?
Im going to a Porsche show/swap in about a week. Now, I am going to be on the hunt for 944 aluminum trailing arms and brakes to match, if I can find them. Now, the big question is this: is there a specific year(s) that will NOT work with my 72 super?
Thanks in advance.
Mike Serrone
///BrooklynAutoRennen
Old April 22nd 2003, 17:50
40 looks and NOBODY knows?
Mike Serrone
Old April 22nd 2003, 20:07
LOAF's Avatar
LOAF LOAF is offline
I'm no expert but..
As I mention above.. No expert but going thru the same...
As far as trailing arm goes.. I think most years will work.. I got 87 but haven't put them on yet... Years/Models that have Alum will widen track..
For the Front this one is tricky.. From others who have helped and given me advice.. As far as 944's go.. go with 83-85.. these have the right config to merry up to a 1303 suspension arm..
I bought 87's (87 on..)and it has been a hasle finding struts.. Ended up getting 84 spindles and hubs to mate my calipers to.. 86 is good but no hole for speedo.. (this is what i was told..) This was for non turbo models..
Now I am waiting for the mail man to come..
Hope this helps..
ALex
also a
Old April 22nd 2003, 20:26
Alex's Avatar
Alex Alex is offline
All of them will work but the track increase is less with 85 924S ones or 86 944 Turbos. I was told that mine are actually of a 924S but the part number is a 951....so I do not know how reliable the 924 info is.
It is easy to identify the later ones.....87 and up. The disk has a big offset and if it does not have the disk on the hub with the studs does not sit flat on the aluminum arm. It looks like a cone. That is were the increased track width comes from.
Hope this helps.
Old April 23rd 2003, 14:41
GUTTERS GUTTERS is offline
alex, my alloy arms are off a 924s, i removed them myself and they also start with 951 on the first part of the part number.
Old April 23rd 2003, 15:21
Superman
Porsche made 2 arms, known as early or late. They have several different part numbers, even for the same part. The 924S has the same arms as the "early" 944 arms. I have pic and will try and find and post...
...okay I found the pic but this is a suspension question so the answer is here:
http://www.germanlook.com/Forums/sho...&threadid=1993
Old April 23rd 2003, 16:30
Superman
You can see this on the bottom arm in the pic.
Old April 23rd 2003, 16:37
vujade's Avatar
vujade vujade is offline
Supe those measurements you gave include the brakes too, dont they?
WinterJam 2010
Old April 23rd 2003, 16:39
Superman
Yeppers
