Old July 10th 2003, 13:49
Spooger Spooger is offline
Question Cam Selection for combination street & offroad
I am building a motor to use in my hummer style kit car.
The specifications on the motor are thus:
82x94 PC
Full Flow Oil
Dual 44IDF
AJ Sims Level 6 Heads 42 X 37.5 valves, Dual valve springs
1.4 Scat Rockers (Optional depending on Cam advice)
Mallory Unilite
1 5/8 Phoenix Header
9.5:1 Compression expected
Rotating Assembly Balanced
All German Doghouse Tin.
I would like some advice on what Cam to use with this engine that would provide the following attributes:
Good low-mid range torque without sacrificing too much on the top end. The vehicle will be used some off-road but mostly street driven. It will be a daily driver (hopefully)
I am partial to WebCam but any and all suggestions would be welcome.
Thanks...
...Steve
Old July 10th 2003, 14:42
Tony Z Tony Z is offline
I think a web 86B will work wonders. If you need more low down torque, try look for something a little smaller
1969 VW aka Suicyde
www.geocities.com/suicyde_vw
Tony__Z@hotmail.com
Old July 10th 2003, 16:36
Massive Type IV's Avatar
122/125 with a stock...without a doubt.
The 86B is not a torque cam.........for pure torque try a 218.
Jake Raby
Old July 10th 2003, 17:11
Jake,
What is the fundamental performance difference or application difference between the 122/125 and the 218?
Thanks in advance...
...Steve
