Go Back   GermanLook Forums > General > Members Rides
Old January 1st 1970, 00:00
Alex's Avatar
Alex Alex is offline
Questions about Alexs ride
Old August 18th 2002, 19:04
bugsoup bugsoup is offline
Question rear coil overs
Can't wait to see how the project turns out. I have several questions about the rear suspension:
Are you using aluminum semi trailing arms with coil overs? How did you handle the bottom shock mount? Are you worried about the strength of the aluminum at this mount? What are you using to replace the spring plates?
thanks
Scott
thanks
Scott
My Blog
Please help me get a minimac
Parts I Need
1965 Beetle "Gordie", 1956 GL Beetle
Old August 18th 2002, 21:56
Alex's Avatar
Yes I am using the 944 Turbo aluminum trailing arms. I am not worried about the bottom shock mount. You were also able to get 944 coilover kits so I am sure the trailing will be fine. The major concern is the top shcok mount with coilovers and bugs. That is one reason for using the Cup brace and adding the 2 extra braces. The other of course is to eliminate wheel hop.
I am using Remmele Uniball springplate. You can see a pic of them in the Suspension Gallery. The torsion bars are removed.
Hope that helps,
Old July 12th 2003, 08:26
Vincent's Avatar
Vincent Vincent is offline
Where can I see some pics of your ride Alex?
Vincent W. Strader
04 Mitsubishi Lancer
plans
power 13b Turbo Rotary 300 hp
Wheels 18" turbo twists
Old July 12th 2003, 08:40
Superman
In the member's rides gallery that can be accessed through the main page of the website (not forum).
