Old September 17th 2004, 18:22
T151 T151 is offline
944 Spring Plate Differences
Are there any differences between the 944 spring plates across the years?
Got Late Alloy arms and ?? Spring plates and they done seem to want to mate!!
Old September 17th 2004, 19:50
yetibone's Avatar
yetibone yetibone is offline
Look for '87+ 944S, 944S2, 951, 952, or 968 spring plates.
If you have "Late" control arms, that's what cars they would have come from.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old September 17th 2004, 22:45
boygenius's Avatar
The early late aluminum arms spring plates should be the same. 1985.5 to 1986 and the late 1987 + all have the same mounting hole pattern. Zen did the swap from early aluminum arms to late aluminum arms without changing his spring plates, I think...
Old September 18th 2004, 00:08
correct. spring plate goes inboard of the trailing arm at the mounting surface.
Old September 18th 2004, 02:16
Would I be right in saying that steel arm spring plates do not fit alloy arms?
Old September 18th 2004, 09:14
yetibone's Avatar
As far as I could tell T151, that is correct. I just checked and compared some parts I have in the basement. Steel arms will not work with spring plates for aluminum arms, and aluminum arms will not work with spring plates for steel arms. The control arm-to-spring plate bolt patterns are different.
944 steel arms have the same spring plate bolt pattern as stock VW. 944 aluminum arms (wide, or narrow) have a different bolt pattern that doesn't match the spring plates on VW Type I's, Porsche 924's, or 944's with 8 valve, normally asperated engines.
Yetibone
'71 1302S 1.8
'73 1303S 2.3
'83 928S 4.7
Old September 18th 2004, 13:23
Thanks!
Off to the breaker then to look for 'aluminum arm' spring plates,
Old September 25th 2004, 14:38
Michael Ghia's Avatar
Spring plate differences....
Heres a pic
MG
