Old December 20th 2004, 10:15
NCbug NCbug is offline
will 17 fit with my struts
will 17 by 7 with an 40 or 42mm offset fit on my 72sb without hitting my struts. if they do what should i do , i heard you can put civic rear coils to replace the stock coil and that will give me enough room but i dont know. and how low can you make your car with 17s. thanx
Old December 20th 2004, 11:31
vujade's Avatar
vujade vujade is offline
you would probably have to run about a 10 to 15 mm spacer to bring the wheels off the struts with stock springs.
With 17" rims and 40 series tires you can lower your car 2.5" to 3" in the front.
WinterJam 2010
Old December 20th 2004, 18:45
if i put a spacer do you think i it will rub against the fender
Old December 21st 2004, 03:11
Superman
Get the MaXX struts from Topline Parts and you'll be fine, a small spacer of about 10mm may be needed.
Old December 25th 2004, 14:57
flat flat is offline
We'll, VdubCustoms were the originators of the honda rear coil, so I have to say that that will work. My car has exactly the same setup right now; adjusta struts with honda rear coils, 215/40 tires on 17x7et42.
Good Luck,
www.vdubengineering.com
