Old February 17th 2005, 01:15
Schweeeeet!!!
Old February 21st 2005, 21:21
Awesome!
T4 2666 1303s
Old February 26th 2005, 08:11
Dasdubber's Avatar
Rear fenders on, popouts in, doors slowly coming together. Have to raise the rear end a little as there is not enough clearance for the extractors - won't have to go up much, just a little.
Old February 26th 2005, 13:52
Racelook's Avatar
Racelook Racelook is offline
I just love it!!!
Keep up the good work mate
Wiebrand
B-Extreme B-Tuning.....
Old February 26th 2005, 14:08
libila libila is offline
Wonderful work. I absolutly love that color!
Old February 26th 2005, 14:35
randyj randyj is offline
Dasdubber,
Your paint job looks great!
What paint setup did you use, paint gun, compressor, hvlp?
Randy
Old March 1st 2005, 07:38
Dasdubber's Avatar
Red face
Will have to check out brand, but was just an entry level high efficiency (thats what the box says!) gravity feed gun similar to HVLP but not exactly the same. 15cfm single cylinder compressor (not sure of tank size), with normal regulator close to tank plus additional filter and water trap/regulator after about 5m of hose (screwed to wall). Spies Hecker products used throughout from etch primer to high build as well as base and clear coat.
If you like I can look at the gun brand (I was told it was the level a spray paint apprentice would use [around AU$250]) - did the job well for me and certainly resulted in a lot less loss of paint through overspray than my first gravity feed gun (which required more air pressure).
hope this helps?
Old March 1st 2005, 07:46
Dasdubber's Avatar
This pic is a little blurry but trim etc is slowly finding its way back on the beetle after some time consuming polishing with my bench grinder/buffer.
Old March 5th 2005, 01:35
DrDuktayp DrDuktayp is offline
Wow! That is Sweet!
What a beauty!
Steering wheel is on the 'wrong' side though.
-grin-
DrDuktayp
Old March 6th 2005, 07:32
Dasdubber's Avatar
Decklid back on, windscreen and rear window back in, doors slowly coming together (I hate inner and outer scrapers!), steering wheel back on (the correct side)
Nothing too major but all this fiddly stuff takes time!
Old March 11th 2005, 16:26
Troy_Audio's Avatar
your illness is beyond a cure..lol
That is 1 of my favret bugs now..
It's just too clean to not love..so when will you deliver my dream car?
Peace Troy
My Project
Old March 13th 2005, 08:08
Dasdubber's Avatar
Cheers Troy! It certainly has been a labour of love...spent way more time and money than originally estimated (but hey, thats a full resto for ya).
The light is at the end of the tunnel....still a faint distant light, but it is there!
Bolted up (for trial fit) the 80mm narrowed beam and all other suspension/brake components...and temporarily added some washers behind the wheels to determine the spacer width I will require (around 16-20mm) to regain the turning circle! Wheels are tucking under quite nicely at the moment.
Old March 14th 2005, 19:13
its lookin sweet down there man....oh BTW...I dont kow if this was answered earlier but are your fenders windend any?
VolkSport Kfer Gruppe
www.VolkSport.net
Old March 14th 2005, 23:21
Dasdubber's Avatar
Stock width all round (only mods to fenders is front indicators have been shaved). They look a little wide in the pics but they are standard.
Old March 15th 2005, 04:53
Are those 18' or 17' turbotwist? Awesome just awesome!
T4 2666 1303s
