#31
So here some updates where I didn't had time for in the last week
On sunday one week ago, I resumed making my own mid mount. I almost spent an half day at it, but hell yeah it saves some (hard needed) money. But everything looks damn sexy!! B-Tuning Productions all the way :wink: ![]() Detailpic http://www.keversite.nl/fotoalbum/fo...2005000724.jpg Picture of the mid mount ![]() I also welded the front brackets off, so everything is verry studdy. On the monday I most of the time drived around to get stuff. I also welded some pieces of my handbrake-bracket. Welded some nuts in the chassistunnel so I can bolt the handbrakebracket on my tunnel. On Wednesday i work hole the day on my car. I also today got my front trailingsarm back were the bushings were pushed out. http://www.keversite.nl/fotoalbum/fo...2005000843.jpg
B-Extreme B-Tuning..... Racebug is comming to get ya!!! |
#32
Wednesday one week ago i welded several unused holes close in the chassistunnel, so it stays one clean thing. Also is the hole for the original handbrakecables enlarged so I still can use them on my hydraulic handbrake.
An little bit unclear picture, maja ![]() Handbrake-bracket is on. ![]() Two holes in the bracket so the handbrake-cables still can be used. http://www.keversite.nl/fotoalbum/fo...2005001202.jpg Last one ![]() I also maked an big "cage" so could sandbalst my car one day later (thursday). Grt Wiebrand
#33
On thursday one week ago (I know I'm verry bussy with my car so I couldn't update earlier ( my car is going to an show this saturday 23 of July, thats why).
Sandblasting works SUPER!!.. one side of my chassis tooked me 45 minutes. You cant keep that up with your grinder. I used an 10m3/min aircompressor, Man that thing blows some air out. On that day the hole chassis was blasted and several pieces of the body we blasted.
#34
On last friday I also have blasted some pieces of the body. ANd looked everything over if I had done every piece as good as it could. Worked till half past eleven that evening.
This are some pictures of thursday (one week ago) Af first our self maded blasting"cage". ![]() http://www.keversite.nl/fotoalbum/fo...2005004759.jpg Chassis and body stands in the blastingcage
#35
On this picture the sandblaster, airfilter for the helme, the helmet and gloves good to see. We hired this one, it was an brand new one (lucky 8) )
![]() This is how it looks after +/- 15 min of blasting, you can't keep it up with your grinder.
#36
.... NAKED TO THE BARE METAL... Just what I love
![]() The "small" compressor we use (almost as wide and high as our bus) is an 10m3/min compressor. ![]() Chassis is blasted on the backside the front is half way. The weelarches are also blasted as test.
#37
Enginecompartment is blasted. The rust that you can see is after this pic also blasted away.
![]() Wielarches, enginecompartment, raingutter, windowgutters and "kokerbalken" were blasted ![]() Chassis in the epoxy primer ![]() http://www.keversite.nl/fotoalbum/fo...2005002401.jpg p.s. the underside was then not yet painted Grt Wiebrand
#38
wow, you're a very bussy bee . Good job I must say :agree:
#39
This is an post from last monday evening when I came home from my bug:
At first I'm tired of al that blasting that I've done the last days. But yeah A couple of pics of past sunday (sunday one week ago); So looks an clear chassis (blasted). ![]() And now the pics of last monday; The past days the body is blasted, see some pics downwards. Ever seen so clear body? Underside of the tiretrunk (is that is the english word for it). http://www.keversite.nl/fotoalbum/fo...2005005455.jpg Strut"holders" http://www.keversite.nl/fotoalbum/fo...2005005539.jpg
#40
http://www.keversite.nl/fotoalbum/fo...2005005625.jpg Blasted body hangs in the construction so it can turn overhead. ![]() The hired compressor ABIRD (Industrial Rental Service) ![]() (Stays an big thing) Body blasted; ![]() http://www.keversite.nl/fotoalbum/fo...2005005914.jpg http://www.keversite.nl/fotoalbum/fo...2005005935.jpg
#41
What an clear thing.. (Try to do this with an grinder).
![]() http://www.keversite.nl/fotoalbum/fo...2005010149.jpg And an little pic of some pieces that my brother blasted yesterday. ![]() -Front control arms -IRS arms -Torsionplates -Gearbox-bracket Also today some little parts blasted; -Window runway of the doors -The edges of 3 bunnethoods blasted. The original one comes out to be the best one. -Gearbox-bracket -Enginehood the underside blasted -Torsionplates -And some tubes of the rollcage After that I cleaned up an bit (because the compressor has to be back on monday morning (now almost an week ago). After that I scotched the body with P180 and cleaned the body with thinner. What an work was that (almost 4 hours of work to do the completed body). And after that the body finally set in the expensive Epoxy Primer. Fast some pics of the body in epoxy. ![]() ![]() Grt Wiebrand
#42
SSSSSSSOOOOOO last thursday I've done something on my car (after I have worked the hole day).
This was finally the first night in two weeks that goes smooth. Everything goes as planned (what was not in the past couple of days :? ) At first I picked up the handbrakelever, then it was machined to the right diameter and after that the anti-slip traction was machined on it (don't knopw the right words for it). .. WHAT AN BEAUTY :shock: .. I'm just proud of it.... An handmade hydraulic handbrake that just looks damn nice also. After that i welded something on the handbrakebracket and put everything together. http://www.keversite.nl/fotoalbum/fo...2005001844.jpg ![]() ![]() After that the rollcage was scotched, cleaned with thinner and around midnight set in the EP. ![]() ![]() The last friday I have to do verry verry much to be ready for the show on last saturday.
#43
Saturday there was an circuitday in Holland, where I was infited for showing my bug..
This is how my car looks for now ![]() The circuitday was great, lots of racing and lots to do. Greetings Wiebrand
#44
he wiebrand
I saw youre car on the circuitday nice looking man. :agree: but one question you have a hydralic hand brake. but in holland it is Ilegal to have youre normal brakes and hand brake on the same line . I dont now if know that.
90 in to te corner. |
#45
See this pic http://www.keversite.nl/fotoalbum/fo...2005001227.jpg Have I spooking with you? What for an bug do you have? (pic?) Greetings Wiebrand p.s. It was an long drive from Leende to Lelystad, buth it was worth all the positive reactions.
| Currently Active Users Viewing This Thread: 5 (0 members and 5 guests) | |
