Go Back   GermanLook Forums > General > Members Rides
Old January 1st 1970, 00:00
Lazarus's Avatar
Lazarus Lazarus is offline
Questions about preg911s ride
Click here for more information on this ride.
Old January 1st 2004, 03:27
jrinlv jrinlv is offline
How bad is that rust?? Are you going to repair it or find a new body? Let us know. JR
Old January 1st 2004, 13:16
Lazarus's Avatar
dont know yet probably try to repair looking 4 suggestions
Old April 3rd 2004, 01:27
Lazarus's Avatar
rust repair
found some one to do the repair the quarters were completly replaced on both sides . anywhere there was foam there was rust only bad design on the cars, except 60 hp and lower from factory but thats an easy fix, not bad for 60 years
Old May 31st 2005, 19:37
Uber Affe's Avatar
sheeesh!
Good Gawd! makes me wonder what's under MY vents!
Good to know at least there's a way to fix it...=)
Lookin good.
Old May 31st 2005, 22:39
Lazarus's Avatar
Talking
thanks for the compliment. if your car is from texas there probably is not much worry in the form of rust as the climate is more dry than here . if youve never been here think of a swamp w/o the marsh lands. we have terrible humidity as of 10:25 pm the humidity is about 85% pretty normal day too. thats were most of the rust comes from here. that and almost no one takes care of their old cars just park them out back and forget them. oh yeah almost forgot the quarters are mid america.
Old October 6th 2005, 09:43
Aircoupe's Avatar
Aircoupe Aircoupe is offline
Thumbs up Rear Fenders?
I started a beetle project this summer, your car was certainly one of the inspirations for my project. I have put on the topline goodies like the 4 wheel disc brakes, Maxx Struts, 7/8' swaybar in front and added a new set of gas bilsteins in the rear. I also have the same style Porsche rims that you are running with 205/40's in front and 255/40's in the rear. So now I need wider fenders for the rear, I see that you are running them only 2" wider, I was not sure that world be enough, I just put them on last night and eyeballed them and was thinking it may require fenders 3" wider. I'm also running 1.5" spacer/adapters on the rear hubs to get the 17x9's (55mm offset) to clear. Are you using a 1.5" adapter? And 2" wider fenders gives you good clearance?
Thanks,
Mitch
74 SB
Old October 6th 2005, 10:47
Lazarus's Avatar
Cool, nice to see a GL brother over in york.yes i did use 1.5 inch adapters only because i didnt want to cut the bump stops. and 2inch wider fenders will work unless you plan to cut the bump stops then i think stock fenders will work. also the wider fenders look cool with the wider stance. send or post some pics id like to see what you're doing.have you looked into vkg? check the website at www.volksport.net
Old October 14th 2005, 10:04
Aircoupe's Avatar
Question
Sorry...I was slow in responding. Yes I have joined VKG and will try to get some photos posted and a blog going. Looks like Zen is still working on the site, but when its ready i'll get something up there....My SB looks better in pictures than up close any way .
One more question regarding your rear fenders, I need to order some, right now I have the backend jacked up like a late 60's Nova to to keep the fenders off the tires. I looked at CCC's website and they appear to only have 1.25" and 3", I also looked at MarkV, they have the 2" wider fenders, but no recess for the stock tail lights. Where to you get you fenders?
Thanks,
Mitch
74SB
Old October 17th 2005, 09:45
Lazarus's Avatar
i got mine from ccc seems like they were 1.5 or 2 inch wider i cant remember.
Old May 5th 2006, 14:58
TOW74 TOW74 is offline
Hello Lazarus,
What year turn signals are you using, because I want to use the early style signals on my super cabrio. By the way the car looks "OFF THE CHAIN!!!".
Thanks, TOW74
Old May 10th 2006, 20:20
Lazarus's Avatar
thanks for the compliment. i think those are off either a 68 or 69 im not sure. i will tell you this if you put these on your super more than likely you will have to do away with the park lights on the front, but thats ok cause its not 1986 and no one drives around with just park lights on anymore.
