Old October 22nd 2005, 22:00
flat flat is offline
Shop cleanup...again..T4 and Porsche parts
I've got some more stuff up for sale:
911 Shifter from early 70's 911. $C110
Baby weber carbs 34 ICT's. No linkage $C120/set
Bug (4 bolt) to chevy wheel adaptors. I only have 3 so...$30all
www.vdubengineering.com
Old October 22nd 2005, 22:02
Bus brakes for baywindow. Calipers are not frozen, and come with good pads. $60/set
87 944 spindles/dusk shields $C50/pr
914 gauge pod, no Speedo $C50
Old October 22nd 2005, 22:03
944 Fuel rail with regulator/injectors $C40
944 Master cylinder was experimental super-beetle adaptor $C90
T4 oil coolers $C40/pr
3 T1 engine cases:
as41 stock (not cut) big stud $C100 my ex engine before rod #1 gave up
as41 stock(not cut) small stud $C80
as41 cut (0.020) small stud $C60
Rear 944 sway bar $C60
Old October 22nd 2005, 22:07
LOAF's Avatar
LOAF LOAF is offline
I will take the shifter..will work with a 901/911 tranny right?
How do you want me to pay..
Please let me know via PM or post
ALex
NNJ
also a
Old October 22nd 2005, 22:08
3 - Dellorto 45 carbs
1st one is like new, everything is smooth as butter (45D)
2nd on has a tight throttle shaft, not smooth(45S)
3rd has a very tight throttle shaft and the throttle blades are removed (45D)
Lots of extra jets, emulsion tubes, main jet holders etc. Some extra 28 vents, a couple 35 vents and one 42 vent (I don't think this one if Dellorto, possible IDA). Has T1 manifolds, air cleaner brackets, etc. No linkage.
$C580/all
Old October 22nd 2005, 22:20
T4 1.8 Rods/Crank $C120,T1 Stock 69 Crank $C100 (stock, never cut)
T4 2L Rod/Cranks $C180
Old October 22nd 2005, 22:25
Loaf,
Yeah, it's from an early 911. Email me lanner@vdubcustoms.com with your address so I can generate a shipping quote.
Easy,
Old October 23rd 2005, 02:22
jrinlv jrinlv is offline
what condition is the TIV 2L crank and rods? Are all the surfaces smooth still? And is it all stock? Thanks JR
Old October 23rd 2005, 17:52
The 2L crank and rods are in really nice condition. I was going to build a motor with them, and I only intended to micro-polish the journals.
Old October 23rd 2005, 18:02
More stuff:
New aluminum oil cooler (really light). Used SPAL fan (the fan has been dropped and suffered accordingly by breaking one of the 4 mounting tabs).The fan is still definately usable. $C145/set
210MM bus flywheel. Ideal for the T4 motor to T1 tranny engine swap. Needs some machining to fit the pilot bearing. $C65
Early 944 (84ish) spindles with backing plates (for 1303-944 conversion). $C70/pr
Old November 20th 2006, 20:40
krems krems is offline
that 914 gauge pod has tach & fuel gauges?
Old November 24th 2006, 10:13
Yes,
but it's gone
Old November 25th 2006, 16:31
blueeyes blueeyes is offline
Question
How much with postage to UK please?
Old November 27th 2006, 08:43
Sorry gone.
Old December 5th 2006, 12:46
hencar hencar is offline
210mm Flywheel
Is the 210mm flywheel still available? I have someone who is looking for one.
Henry
