Old November 2nd 2005, 15:36
Turbo Haraune's Avatar
Turbo Haraune Turbo Haraune is offline
911 trailingarms rear
Im planning to replace stock trailing arms with porsche units made of alu.
Im running coilover setup. wich arms should i be loocking for? wich is the best fit?
Model,year, etc...
Vin
Check out my project pic`s!
http://www.v-dubs.no/haraune
Old November 3rd 2005, 09:20
from what I have seen (someone correct me if I'm wrong!), 86 944 turbo ally arms will bolt on with no track increase, there are two other widths from other years, not sure which are which, 911 arms are too long so will lengthen your track..
Rich
Old November 3rd 2005, 13:06
Lengthening the track isnt nessesarly a bad thing... it would give better weight distribution. But ofcourse more than 30-40mm would be a problem.
Old November 4th 2005, 11:26
lazylongboarder's Avatar
lazylongboarder lazylongboarder is offline
I have some late model aluminum arms that i'm selling. I would love to use them but I'm using a 993 multi-link rear suspension setup. Let me know if you are interested. They are complete with rotors, hubs, calipers, ebrake cables'... everything. I have the original porsche rubber bushings in them as well as new red urethane bushings, and i have original vw allen style bolts to hold the arms and I also have the new bolts from aircooled.net that use a 20 mm wrench which are $18 each. Fully complete with everything. Let me know and i'll post some pictures of everything.
1974 type 1
Turbo 6 piston brakes at all corners
Project is taking all my money and it's all Germanlook.com's fault!
98' Audi A4
93' T-Bird (oh yeah!)
90' 911 C2
74' beetle
