Old December 1st 2002, 23:23
vujade's Avatar
vujade vujade is offline
Sandeep,
I hear ya man! I was looking at Michael Ghias site today reading up on 944 brakes conversions.
What I would like to use is the 968 crossed drilled & vented rotors with the Big Reds...looks like i can make it work on my 02.
I have to do more research though....
WinterJam 2010
Old December 2nd 2002, 12:45
Joe I'm glad to see the progress on your Supa. What kind of rear sway bar are you gunna run? You are gunna love carving lines on the back roads!
Old December 2nd 2002, 13:07
vujade's Avatar
Not sure about the rear sway bar, though I would like to run a Kafer Cup Brace
WinterJam 2010
Old December 2nd 2002, 13:31
The Kafer Cup Brace is coming up on my list of to do's too. If you put the Topline 7/8" front Sway Bar your gunna need to put one in the back or else the oversteer will be very dangerous.
If your running a stock front sway bar think about the upgrade cause the Topline front S/B also fixes the caster change from dropping the front and doesn't put a big angle on the bushing for the S/B to control arm.
Nick
Old December 2nd 2002, 14:24
vujade's Avatar
Supa
I did buy the Topline 7/8 sway bar, strut tower bar & also their bump steer kit as well.
Should I run a sway bar in the rear in addition to the Kafer Cup Brace, or will the KC Brace suffice?
WinterJam 2010
Old December 2nd 2002, 17:32
Joe,
I'm no suspension expert but the Kafer Cup Brace just acts like a strut brace/ traction bar. It won't prevent body roll. I highly recommend a rear sway bar and then I'd worry about the brace.
Nick
Old December 2nd 2002, 17:35
lightning bug's Avatar
Your brace MIGHT suffice. The brace is more for traction and tying the rear suspension in with the frame. Try it without a swaybar, if you have too much oversteer add one. This is something I've been pondering also as I have both the swaybar and the brace. Its going to be trial and error. You just have to be smart about it. Go to a parking lot or somewhere to try it out. Remember.. oversteer is always better than understeer.
Julian
'74 Super
Old December 2nd 2002, 17:36
Alex's Avatar
Alex Alex is offline
The brace has nothing to do with a swaybar. They do different things.
The brace will tie in the tranny horns with the top shock tower for less wheel hop and the swaybar will connect both trailing arms with each other for less body roll depending on the stiffness of the swaybar.
I hope I explained it right.
Old December 2nd 2002, 18:05
Philippe Philippe is offline
The Kafer cup brace also reduces body flex, sort of like the front strut braces on a super.
It will make everything tighter around the corners, but you will still have the problem of body roll without a swaybar.
On the volksworld webpage there are some videos of this silver superbeetle, and if its the one I think it is, he's running a seriously beefed up suspension, Heigo front stressbar, crazy heigo cage, and a heigo kafer cup style brace.
This guy is drifting around this circular track, his tires are spinning and his car is FLAT FLAT FLAT. Amazing.
http://www.volksworld.com/content/down/down01.html
the videos are Kreis Kuke & Kreis Kuke 2. ENJOY!
Old December 2nd 2002, 18:27
Alex's Avatar
Cool videos....that Oval looked like the one from Gerd Weiser.
Old December 2nd 2002, 21:28
The brace will tie in the tranny horns with the top shock tower fro less wheel hop and the swaybar will connect both trailing arms with each other for less body roll depending on the stiffness of the swaybar.
That's exactly what I was getting at. I stress "might" because I'm still researching. I added a front (bigger) swaybar to my Rabbit and it was a mistake. Too much understeer. I figured its a bigger swaybar, its got to be better. wrong. Now I research things before I buy. Sorry to cause confusion if I did.
Julian
'74 Super
Old December 2nd 2002, 22:22
so what is that nice big crunch about 2/3 through Kreis Kuke?
