Old December 30th 2005, 15:44
Aircooled 6-cylinder 2,7 ltr, not porsche...
Its the chevrolet Corvair engine!
Actually ahead of its time, its a lot like a type 4 engine, but has two cylinders more and sports 2,7 ltr in most versions.
Introduced in 1960 (!), it has an aluminium case like the type 4 and about 87,3mm bore x 74,4 mm stroke. The 'inch' sizes are a bit annoying tho
Also unfortunately it runs the other way around, but there were 'reversion' kits made with special camshafts for use in mostly (dune) buggies.
That also gave the idea to use VW cylinder and pistons which gave very huge size motors:
http://www.corvairkid.com/mm01.htm
About 1.2 million Corvairs were made and it has a large following and many clubs and specialised companys exist. Because of the number of cars made, engines and parts are plentifull and cheap!
So: dare to be different and go corvair 6 cylinder!
I already bought me an engine as it does fit very nicely in the engine bay of cars that ran type 4 engine from the factory, like a certain....VW 412S
Greetings,
Walter
Old December 31st 2005, 13:59
Racelook's Avatar
Racelook Racelook is offline
Do you find such engines also in Holland Walter? Or have you bought him in other lands!
Good to hear from you
Wiebrand
B-Extreme B-Tuning.....
Old December 31st 2005, 16:27
starmember's Avatar
i saw them on marktplaats (a dutch ebay) ones
90 in to te corner.
Old January 1st 2006, 13:06
Mine is one from an originally dutch registered car, but you're right, there are probably very few separate engines available in Europe.
But prices are so low for these engines ($200-$300 range in the US) compared to porsche 6-bangers, that even including shipping, it would still be relatively low budget.
But availability aside, I mean: a 6-cylinder type 4 Just how cool is that!
The funny thing is: 'they' struggle with the same (tuning) issues as us VW mentals do
Old January 1st 2006, 20:59
kleinporsche kleinporsche is offline
Can you post us some links of these forum please Wally? Do you know if it clears a Beetle's engine bay? or there is lots of cutting in the floor and firewall? Thanks
Old January 2nd 2006, 04:45
In a beetle, it would be critical towards the rear apron, but not nearly as bad as a 911 engine; Width however wouldn't be a problem at all.
But I was thinking more about an application in a type 3 or a 411/412, where the extra length of the engine itself would be about the same as a stock type 3 of 4 engine.
There is a fast (cor)vair group on yahoo: http://autos.groups.yahoo.com/group/fastvair/
Walter
Old January 2nd 2006, 09:02
MattKab's Avatar
MattKab MattKab is offline
Hi Wally,
That sounds like a great plan for a 412!!
If the Corvair motor turns the wrong way, can you not fit a 914 tranny in the wrong way, like 2 wrongs make a right?
All the best for the Newyear,
Matt
Old January 2nd 2006, 09:25
Well, that sorta was my intial thought as well to be honest.
No reason to try to make both of them turn the other way around with those parts
Old January 3rd 2006, 23:43
found that for those interested:
http://www.corvair.com/user-cgi/cata...O&page=OTTO-36
On how to fit a Corvair engine to a VW trans.
Old January 19th 2006, 19:12
jmd's Avatar
jmd jmd is offline
corvair in an 69 IRS...
Guys,
I have a corvair powered 69' Baja Bug...
I just wanted to share with you all and see if any one has any questions. The place to talk to would be Clarks Corvair http://www.corvair.com . Also review here: http://www.corvair.com/user-cgi/pages.cgi?category=vw... (realizing this has been sortof posted above)
I also have a parts list that can be posted to those that are interested in what it will take to complete the conversion. This motor is beefy, piles of torque and will, with stock vw tranny, lift the front wheels off the ground under a full-hook-up launch.
Questions:
1. Is it an easy swap?
- mostly save the need for reverse rotation
2. what about adapter plates?
- Clarks has all you need and are great to work with.
3. Spendy?
- no, the challenge is finding people to turn wrenches on it.
4. Weight?
- about 250lbs more then a stock motor. which is enough to notice...
5. Cooling?
- I cannot overstate the importance of cooling this motor... take the time.
Hope that covers it all, and as my first post, thanks for the forum!
- no longer lurking -
---jmd---
Old January 20th 2006, 04:30
Cool!
Thanks for posting jmd.
I hope to have located my conversion flywheel and adapter through ebay.
I think/hope you are somewhat off on the weight, but we'll see when I get to it to weight the whole thing.
Regards,
Walter
Old January 20th 2006, 17:53
flat flat is offline
I've got a complete longblock. If you need parts let me know. Also, there is a guy around here who has a TON of 'vair parts, so if you ever need something wierd.....
www.vdubengineering.com
Old January 21st 2006, 06:00
Thanks man!
