Old February 17th 2006, 14:37
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Originally Posted by Mikey
A 9" rim with no tire maybe. The inside will hold a 9" wide wheel, but you run into the spring plate, then the shock tower. A narrowed rear tortion would fix that. But that's almost too much for a 2inch wider rim.
So are you saying that if the spring plate was thinner (or bowed for clearance), and the shock tower were shortened, that the 9" would fit in your opinion?
Old February 17th 2006, 23:48
Mikey's Avatar
Mikey Mikey is offline
I don't think you could get that thin of a spring plate. or bow it almost 2 inches.
hmmm.... You'd have to basicly take an inch or two out of the rear torsion housing. (just like narrowing a front beam.) In effect it'll move the spring plate/shocktower closer to the tranny. With that you're looking at either adapting stock vw torsion bars, a custom torsion bars, or coil overs. Then, and probably only then, would you be able to fit a 9" rear wheel with no body mods. There is plenty of room from the wheel to the shock tower in the original position, but it'll be almost impossible or too much work to move the spring plate and not move the shock tower.
If I had more skill in shaping metal I'd just widen the rear fenders, and put a set of 9" in the back. But then again, I'd widen the front too so I can use a stock beam.
Mike
'04 R32 Tornado Red
Old January 6th 2008, 09:38
hpw hpw is offline
Originally Posted by Mikey View Post
Finaly, I figured out how to resize. The first 2 of my front after I put in a 2in narrowed beam, drop spindles, and adjusters. This is the lowest it'll go, I'll raise it up an inch or 2 for final ride height.
The last 3 are after I put the rear wheel on today. I think it looks good, and I have no clue what possesed me into thinking a 9" would fit. A 9" rim with no tire maybe. The inside will hold a 9" wide wheel, but you run into the spring plate, then the shock tower. A narrowed rear tortion would fix that. But that's almost too much for a 2inch wider rim. 10"s maybe?... Either way. This is what I have right now. The back will settle a little more and I'll lower it more too.
What you guys think?
Mikey, new to this forum, usually post on the samba, but I was wondering
if you had any updates on your car?
Old February 21st 2008, 23:17
flat_iv flat_iv is offline
16x6 1/2 wheels 205/45/16 tires on the front and 205/50/16 on the rear. Dropped Spindles and 1 spline lowered in the rear. The offset on the wheels are 46ET. No wheel spacers on the front and 5/16 spacer on the rear. Carefull on the tire cross sections. All tires are not created equal. For example I found some 205's that had a cross section from 7.8 to 8.4. Doesnt sound like much on a normal car but on a Ghia its a mile....
Old February 22nd 2008, 12:14
vwdevotee
Sweet ride. What wheels are those?
Old February 22nd 2008, 12:16
vwdevotee
I'm eyeing 8 inch wides on my rear also ('73 Ghia). Any news? I measured from teh outside of my current tires (EMPI 8 spokes, very close to the fender) to the spring plate and got 10 inches. I also measured at the top to the inner fender and got 11 inches. It looks like everything will fit, I just want to hear from someone who has done it before I drop 2500USD on wheels and tires.
Old February 22nd 2008, 13:51
DORIGTT's Avatar
Hey flatIV,
What brand and model tire are you using? I would like to research the specs (physical dimensions).
What are you using for rotor/drums to attach those wheels/rotors?
Old March 28th 2008, 17:48
vwbao vwbao is offline
hi, is it narrowed beam? does it rub?thanks
Old September 5th 2008, 00:39
vwdevotee
No updates?
Old September 6th 2008, 14:47
brujo65 brujo65 is offline
this is my 74 with custom Forgeline 7 1/2 front and 9 rear with out any
flares
Old September 6th 2008, 14:53
vwdevotee
What are the specs on the wheels? 17s, 18s? What offset? What suspension parts are you using? What mods do they have?
Old September 6th 2008, 15:12
the wheels 17 with custom offset to fit the body and 944 steel control
arms with 944 turbo brake front and rear and suby 2.0 RA turbo engine and
coil over front / rear
Old September 6th 2008, 15:20
Nice! I'd love to see some more pics of the car/build...
Rich
Old September 6th 2008, 20:01
vwbloodline's Avatar
vwbloodline vwbloodline is offline
Rich
x2 :music4:
Old September 6th 2008, 20:05
vwdevotee
What offset did you end up needing?
