Old March 5th 2006, 20:23
Racelook's Avatar
Racelook Racelook is offline
Thanks for the nice words guys!!
Always good for the motivation
Past thursday grinded some weldings at the chassishead.
http://www.keversite.nl/fotoalbum/fotos/25686.jpg
After that started with "blocking" with P180.
http://www.keversite.nl/fotoalbum/fotos/25684.jpg
Saterdayevening (after work) spend another 4,5 hours (till midight) with cleaning the barn and masking it with plastic.
B-Extreme B-Tuning.....
Old March 5th 2006, 20:24
Racelook's Avatar
So today another hour or 10 worked on the car.
As first the underside of the chassis cleaned with "silicone-remover".
http://www.keversite.nl/fotoalbum/fotos/26289.jpg
And then the painting could start.
First good heating, with an air-canon.
http://www.keversite.nl/fotoalbum/fotos/26293.jpg
"Throw-away-cup" made
Underside of the chassis painted in Epoxy Primer. Onderzijde
Upside of the chassis painted in EP.
http://www.keversite.nl/fotoalbum/fotos/26296.jpg
And some lose pieces of the chassis in the EP.
http://www.keversite.nl/fotoalbum/fotos/26300.jpg
That's it.
Wiebrand
Old March 6th 2006, 10:58
super vw super vw is offline
Sweet!... so what paint(s) are you using for the chassis and mechanical parts?
Lookin good.... those air/heat cannons are cool eh? wish i had one!
Jonathan
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old March 10th 2006, 06:46
Racelook's Avatar
Thanks Jonathan.
I'm using 2 layers of EP (Epoxy Primer), the tunnel will be "plamuren", then all the seams of the chassis will be sealed with "strijkkit", then all the underside of the chassis and trailingarms will be set in "Bodyschutz", then most things will be painted in red or black 2K-paints, and as finish everything will be shot in clear.
For all the paint I use 2K.
p.s. for the thing in the " .. " I don't know the English translation of it.
Yesterdayevening I worked from 7 till 11.30p.m. on my car. Checked several lose pieces of the chassis, brushed some things clear and stored them warm and dry.
After that I got further with the list of bolts and to buy thing till 1.00 a.m.
Wiebrand
Old March 10th 2006, 11:47
Very nice. Im not sure what brand your using for the under coating of the chassis, but i would recomend using a product from Wurth thats called SKS Black.... or if you wanted to paint it body color with stone protection (EXACTLY LIKE PORSCHE UESED) you could use the SKS Grey. the only down side to the Wurth product is that you must use the Wurth Multi sprayer for there products to look correct (looks like the fatory porsche under coat).
We use it a lot on restorations at work... it's the only way to make it look factory porsche. but it would be nice on a beetle to!
Jonathan
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old March 16th 2006, 09:40
Racelook's Avatar
The brand I use for undercoating is Teroson. And I use the grey one.. for an faster and les use of the red paint.
Wurth is also verry good stuff.
Some little update off yesterday.
Bought myself an threatmeasurementtool and checked every lose thing of my car. Measured everything again. And now my list is for 97% completed.
TIME TO BUY SOME NEW STUFF next week.
Wiebrand
Old March 16th 2006, 23:22
Bad bug's Avatar
Bad bug Bad bug is offline
I planon using Por15 on my chasis. What do you guy's think.
Old March 20th 2006, 12:18
Racelook's Avatar
I heared several good things of them.
I stay with EP because then I can also bondo right on it (because there is not going any interior in).
Wiebrand
Old March 20th 2006, 12:25
Racelook's Avatar
Sooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooo what an day was yesterday. This project will be my dead once
Yesterday I maked an 13 hours day at my car.
At 11 o'clock I was in the cold barn. Begun to brush the gearbox clear. What an piece of $h!TT to do... but yeaahhhhhh.
Then brushed some other lose things clear. Blew the tunnel clean. Masked some holes. Also hanged several things and ungreased them.
Racelook's Avatar
Then mixed the paint. So I could shot the layers of EP around midnight.
At first the inside of the tunnel.
Then the lose things.
I could be some nice end of an long day. But I was forgotten that my brother had cleaned the paintinggun and that I haddend to thinner the paint soo much
Wiebrand
Old March 23rd 2006, 19:12
Racelook's Avatar
So tonight found another hour.
Fitting longer threads for mounting midmount.
Threats exchance for the gearbox.
1:
Make longer threads.
Left the original one, on the right 2 new ones.
2:
Remove thread out of gearbox.
Welded an nut on the excisting threats.
Another pic
3:
Prepare new thread.
Twist 2 nuts against each other on the new thread.
Put on Loctite (blue).
Loctite 243
Old March 23rd 2006, 19:13
Racelook's Avatar
4:
Installing new threads.
Differents in lenght is good to see on next picture.
End resultt:
Wiebrand
Old March 24th 2006, 10:48
jonas_linder jonas_linder is offline
No offence (I can't spelling everything either ) but threat is kinda like "danger"!
The correct word is thread
Looks great, I like your project :agree:
Old March 24th 2006, 11:14
oasis's Avatar
oasis oasis is offline
Well, we ain't hear to learn you to speak more better goodly. :drunk:
Old March 24th 2006, 17:21
Racelook's Avatar
Oeps Jonas, you're right. I've changed it now
Today I had picked up something more than the half of the bolts/nuts/rings etc for my 1303..... and you're going verry fast to the 200 euro!!!!
Next time all the bolts will be blasted and passived, but hell yeah this is some special project
p.s. there are +/- 610 pieces of bolts/nuts/rings etc.
After that buyed some stuff at Franky's VW Service (www.kevertuning.nl)
And then I ve spend the hole day on removing the clutchleaver from the clutch-axle. hamering, pulling, heatening. Nothing helped, so I cut it lose.
Wiebrand
