Old July 7th 2006, 11:19
Bullyboy Bullyboy is offline
swaybar for 944 rear
I plan to run the 3/4'" T1 swaybar with my 944 early aluminum arms. Is there any adjusting/welding needed for the mounts? or is it a simple bolt on?
Any pics?
Please and thank you
Mark
Old July 20th 2006, 09:51
So nobody has mounted a T1 swaybar with early aluminum arms???
Old July 20th 2006, 21:21
LLVWGL LLVWGL is offline
If you are using the bugpack swaybar, the ends bolt to the spring plates where they meet the trailing arms, and the center mounts are connected to the torsion tube. So I would imagine that at most, since you are keeping the torsion tube, you may have to elongate or obblong the holes for the end brackets depending on if the bolt pattern (for the spring plates/trailing arms) changes from stock with the use of 944 trailing arms.
