Old August 9th 2006, 10:18
56oval's Avatar
56oval 56oval is offline
height setup for 915 box.
locating the 915 box .its 75mm forward but what height should I go for .where it sit,s now the bottom of the gearbox is level with the gearbox forks or should I move it up higher.any ideas welcome.
cheers Malcolm.
Old August 10th 2006, 05:22
Mikey's Avatar
Mikey Mikey is offline
Any ideas? Personaly I would move it up for ground clearance, but what engine are you going to use?
Is that the tunnel you're using, there is no suspension. What are you going to be doing for suspension? Looks interesting, and I like the way the 915 looks.
Mike
'04 R32 Tornado Red
Old August 10th 2006, 10:28
56oval's Avatar
mike if you look up 56oval title 56moneypit on this forum you,ll see the rear torsion bar set.the motor type4T or subie.
Old August 10th 2006, 11:18
for type 4 I'd leave it at a fairly stock height, for scooby raise it as far as you can keeping it within the stock silhouette of the body.
I thought you were going to use an uncut 944 rear torsion housing though? I would have thought that will dictate how far it can go forwards, if at all..
Rich
Old August 10th 2006, 15:07
Mikey's Avatar
Rich
That's what I had in mind. Because I'm doing a Subaru conversion too. I would liked to have raised the transmisson, but it's a little late for that.
Mike
'04 R32 Tornado Red
Old August 10th 2006, 16:49
you could always raise the rear mount, it would give an angle to the whole trans/engine but acceptable and give a surprising amount of extra ground clearance back at the sump
Rich
Old August 11th 2006, 05:47
56oval's Avatar
Rich I don,t know which motor to use yet so by having the motor 75mm forward will help with the balance of the car with either motor and if I go with a turbo type4 will give me more room and extra height will help exhaust clearance .
Old August 11th 2006, 09:58
If I were you I'd chose which engine to use first. I'm obviously biased towards Suabru, especially the price you guys down under can get them for! With even a mock-up block it would be easier to plan things out as I would want to triangulate some extra bracing in there too..
Rich
Old August 11th 2006, 21:41
56oval's Avatar
even in australia each state has different laws in Victoria if I use a subie engine the car,s pan&body have to have a torsion test and comply with current adr,s & no modification to the motor,but in New South Wales & Western Austalia it doesn,t have to have a torsion test.I,ll set the pan up first eg have it rolling then body last .
cheers Malcolm.
