Old April 19th 2007, 08:56
oasis's Avatar
oasis oasis is offline
Do you think the rear spoiler is more effective for stability than a Kamei front spoiler?
(2004-2008): 1971 1302 w/2056
Old April 20th 2007, 06:34
Chris Percival's Avatar
No, i didn't notice any vibration, but then the rear edge is folded up a little, so I can't see it flexing much, maybe yours is a little different?
Old April 20th 2007, 09:04
No idea really, but I believe the front you will notice more directly. The rear is more tricky when you brake at high speed and the rear suspension is lifted some extra because of this. Also lifting throttle after strong acceleration (i.e turbo'd cars) at high speed can cause an imbalance you really don't like. The rear wing will help counter this to some extent. And you will want all the help you can get at some point
@Chris: you will need to look in the rear view mirror for this you know LOL
yes, mine has the folded-up rear lip as well, but still it happenend. John didn't believe me either tho. Adjusting the mounting points somewhat didn't help either, so I made an extra support.
Old April 20th 2007, 11:54
oasis's Avatar
... I believe the front you will notice more directly. The rear is more tricky when you brake at high speed and the rear suspension is lifted some extra because of this. Also lifting throttle after strong acceleration (i.e turbo'd cars) at high speed can cause an imbalance you really don't like. The rear wing will help counter this to some extent. And you will want all the help you can get at some point ...
Good info. Thanks.
Old April 20th 2007, 20:25
Does the wing have any affect on engine temps?
I used to help a friend with a beetle race car in the 80s, he was persuaded to fit a whale tail to his car and he found it a great help at Sydney track called Amaroo Park, at the end of the straight there was an uphill section, just after cresting the hill there was long right hander, he found the car much more settled after fitting the tail.
Old April 21st 2007, 04:52
I had all 4 CHT's still in place at the track, but couldn't notice any difference in head temps. As the Porsche fan draws mostly from the back side of the license plate opening, its not conclusive for a type 1 style shrouds that draws from under the rear windscreen, but I doubt it would make a difference as there is quit some opening between the body and the wing (unlike the picture at the acn website).
Oil temp stayed well at or below 90 degrees Celcius (190F?) all the time, but the dry-sump gives a much more stable (and a bit lower) oil temp anyways, so I am cheating a bit in that respect also
Old April 22nd 2007, 09:02
Thats a nice wing, still deciding on the one you have and the rear spoiler from J-sports. Beautiful 03! Are you around Amsterdam?
T4 2666 1303s
Old April 22nd 2007, 11:21
Not really, about 80 km's from A'dam
What does the J-sport wing look like?
Old April 22nd 2007, 15:26
judgie's Avatar
judgie judgie is offline
rear wing made a huge differance in lap times on my car and made it driveable over90mph in corners, before the wing the car would feel very unbalanced in high speed sweeping corners.
looks like you had fun
cheers rob
Old April 24th 2007, 19:58
Heres the spoiler from J-sport.
T4 2666 1303s
Old April 25th 2007, 02:11
Thanks! Reminds me a bit about the 'duck-tail' spoiler you had in the 70-80's.
The J-sport does block the upper grill totally tho...
Old April 25th 2007, 04:00
Haha! Ah thats why I didn't notice.. Hmm, its exactly the same, I have no idea why I didn't get the problem. Most odd.
