Old May 6th 2007, 10:07
Pillow's Avatar
Pillow Pillow is offline
IRS Suspension setup thoughts
Okay, in further investigation I am kind of rethinking my "ideal" suspension setup. Please let me know what you all think.
Front:
- KYB GR-2 shocks
- Stock torsion bars
- 3/4" sway bar
- Dropped spindles
- 944 brakes
Rear:
- KYB GR-2 shocks
- 28mm torsion bars
- 3/4" sway bar
- 944 rear arms and brakes
All urethane bushings where it is possible.
The big change is really the 28mm rear bars. Seems like a lot of people have been happy with them on the track.
Also the GR-2 shocks all around. Seems a bit soft, but the suspension should be doing the work, not the shocks beating you to death. I could be wrong here...
Thanks,
Adrian Pillow
'57 Oval Beetle - project
'66 VW Westfalia - GL
'99 GMC Suburban 6.5L Diesel
VolkSport Kafer Gruppe
Old May 7th 2007, 00:42
super vw super vw is offline
I feel the GR2's in the rear or my super can be a little soft and with not enough dampening under higher speed uneven (up and down) roads. i get a wollowing up and down sensation from the back. Although i am running some large wheels in the rear (245/45 R17 tires on 17/ 8.5" wheels) so that can make the shocks less effective.
So personaly im looking for alternatives.
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old May 7th 2007, 20:51
Pillow's Avatar
Super VW, what torsion bars are you running in the rear?
I used to run a '69 Beetle with GR-2 front and Gas-A-Just rear. The rear was hard on minor bumps but would squat on hard turns. IMO pointing to a soft torsion bar.
Thanks,
Adrian Pillow
Old May 8th 2007, 00:21
Im running 26mm bars out back. I could be wrong on the shocks... but this is just what i feel it may be. i have yet to investigate.
Current cars:
-74 Super Beetle
-86 Vanagon Syncro
-64 sunroof bug
-73 thing
Old May 9th 2007, 23:31
Pillow's Avatar
Thanks for the info Super!
If you have the 26mm rear bars then I guess the GR-2s could be weak then
I guess the rear Gas-A-Just might be the way to roll.
Adrian Pillow
