Old June 20th 2007, 11:16
Sunroof53's Avatar
Sunroof53 Sunroof53 is offline
Question Dimensions for 944 hub machining
Hi,
I am buying some brakes from an 86 944 (single piston ).Has anyone got a drawing or dimensions to modify the front hub for a ball joint beam.I probably could work it out but as this is a popular mod i am sure somone has the details to give as close as stock wheel offset.Also can you use the porsche bearings for the back as well as the front .I am aware that you have to make a sleeve for the front (outside) bearing.
I have done some research but cannot find the hub mod dimensions.
thanks in advance.
Old June 21st 2007, 04:55
I have drawings on my site, look in the speedster bit...
Rich
Old June 21st 2007, 06:35
DORIGTT's Avatar
DORIGTT DORIGTT is offline
What was your change in track over the stock setup?
What about the spindle modification?
Old June 21st 2007, 11:40
Sunroof53's Avatar
Sorry mate i havnt done it yet!
Old June 21st 2007, 12:38
Sunroof53's Avatar
Rich
Thanks Ricola ,Your site is has been an inspiration .I Was a toolmaker many years ago ,but still have access to a lathe in my maintenance dept, so i can do the machining myself.Are both the inner and outer bearings vw and are they drum or disc bearings ?not sure if they are the same.Just had one hickup though,i hadnt realized you use a drum stub axle and i have two sets for discs only ,so now need to find some more!Thanks again.
Old June 21st 2007, 15:54
DORIGTT's Avatar
I apologize Skeeter, the question was directed toward Ricola.
Old June 22nd 2007, 04:08
I'm pretty sure that VW drum/disc bearings are the same so that bit's easy. From memory the increase in track was about 9mm?
What about the spindle modification? It was only a matter of spotfacing the mounting face and grinding down a bit for clearance..
Rich
Old June 23rd 2007, 11:38
old gh bug old gh bug is offline
I have just done this conversion and used ricola's excellent drawings i have a nice set up now like you i went and got disc stubs for some reason thinking that was what you needed . when you get the drum stubs you might find that you have to machine down the backing plate locating ring as my hub was just catching also used the dimensions on here for the caliper adaptor plates
Sorry for the rusty pic garage got flooded
Old June 25th 2007, 16:05
Sunroof53's Avatar
Disc stubs
Thanks for the pic ,
I spent some time at the weekend measuring my disc stubs to see if i can use them .I have figures out that i need to drill the two M10s for the bracket 8mm in front of the back plate mounting holes which have the same pitch of 56mm .What i did find strange is that the mounting point measured from the rear bearing shoulder to the caliper mount is the same .This means that i need to gain the 10mm for the bracket.I can gain the 3mm from deepening the hub and the rest from machining the stub axle as you did the drum one .This leaves 10mm of tapped hole for the bracket and makes the caliper sit as the original spec.Of course i then have to cut the original vw mount back.Incidently i have build up up my stubs with weld and machined to use the porka bearing .I may regret this as it seems to use an imperial race 3/4 and 1"1/4.
The wisest mind has something yet to learn
Old June 27th 2007, 08:03
I like the idea of that i did look at using disc stubs first of all but had a set of drum ones laying around so i took the easy route
Iwould be intersested to hear if the welding works as i think i would prefer that to the spacers i have used
Old June 27th 2007, 11:07
Sunroof53's Avatar
I have nearly completed the disc stubs and will post a picture soon .The built up diameters seem ok ,although i did make a spacer for the seal diameter .I did also
have to plug the 7mm tapped hole for the original back plate, as it would just break into the caliper bracket mount holes.What is apparent is the far graeter amount of surface area for the bracket to sit on compared to the drum axle.
I am looking forward to getting this sorted but i still have to narrow the rear trailing arms to finish the major bits .
Old June 27th 2007, 11:47
Chris Percival's Avatar
I have just done this. Write up to follow soon on www.fastbug.net. 944 aluminium hub machined and then fitted with steel inserts to take beetle bearings and oil seal. Drum axles used and all I need is the correct shape steel plate and a spacer to hold the brake caliper. I created detailed CAD drawings which I will also make available.
Old June 27th 2007, 12:05
Sunroof53's Avatar
Thanks ,I went down a diiferent route and used the porsche bearings .Those beetle ones look very small in that 944 hub.
Old June 28th 2007, 11:57
The bearings are not carrying any more weight, so why not use beetle ones..
Here's my solution. Full write up at http://www.fastbug.net/node/219
Using this image you can see the difference between the beetle spindle and Porsche hub.
Spacers where created to go into the hub to hold the beetle bearings. The hub was shortened at the back edge and a spacer inserted to hold the seal.
The result? Custom hubs that use beetle parts, but allow the mounting of a Porsche disc, and with minimal track increase.
Chris aka CSP
Old June 28th 2007, 12:00
I need to use cap screws to hold the caliper mounting plate on to clear the hub. the Porsche dust cap clears the beetle locking nut easily. It might have been easier to mount the caliper with radial mount caliper and disk brake spindles but these calipers were cheap as chips so this was my chosen path..
