Old January 3rd 2008, 20:04
vwdevotee
944 suspension
I've noticed that an '86 Turbo seems to be the prefered suspension for GL's; why is that? Other than the narrowed track (compared to later years) what advantage does the '86 have?
Old January 4th 2008, 11:02
Superman
That is the advantage, all the others you'll need wider fenders.
Old January 4th 2008, 14:27
vwdevotee
Are the brake components the same for an '86 and '87+ Turbo?
Old January 4th 2008, 22:14
The rotor's are different, but e-brake shoes are same. The calipers are same (4 pot Brembos)
Old January 6th 2008, 03:52
Superman
The calipers are not the same, '86 was a one year only. Although they look similar outwardly, the piston design is different.
Old January 6th 2008, 22:32
Yes there are two different types of pistons, but the bolt pattern is the same. Here is a pic of the different types, and seals.
Old January 7th 2008, 12:21
vwdevotee
So I could put later calipers onto '86 bits?
Old January 7th 2008, 17:20
vwdevotee
Is there a significant difference in the braking effort provided?
Old January 7th 2008, 22:16
There is one set of early aluminum arms that have NA bolt pattern, but the rest all have same turbo pattern.
Braking will be the same with both piston types. (they just have different type of seal set-up) But some models had different piston sizes on front, they could be 44&38mm MO30 option or 40&36mm. ALL rear turbo's have 30&28mm pistons. If your asking about braking with turbo vs. NA. Turbo is overkill for T1, but I like "the look"
