Old April 14th 2008, 15:27
mopydereefrm
Narrowing my 68 rear? (This is not a diet!)
I would like to narrow my 68 Beetle rear 2" to 2 1/2" for wider tires
and tub my body, any ideas on cutting the trailing arm assembly,
sub-frame, torsion bars, etc???
68 Porschedub project!
Old April 14th 2008, 21:03
If you want to keep the torsion bar set-up Ron Lummus Racing(spelling?) sells some shorter torsion bars, axles, and tubes for this IIRC. Or you can go pro street route and use a four link with coil overs. Also, if this is a IRS pan, then you will have to use a swing axle set-up. There are other more time consuming and $$$$ ways to do this to have IRS though.
Old April 14th 2008, 22:09
flat flat is offline
What wheels and tires are you looking to installing? I've had 235/35-17 tires tuck stock fenders on my super on 17x7 wheels. Also, with the right offset you can get a 8" wheel to tuck....
www.vdubengineering.com
Old April 15th 2008, 10:04
mopydereefrm
I'll check out Lummus Racing, but you have the right idea I had thought of going with a four link with coil overs from Summit racing with modified diagonal arms and lose the torsion bars, spring plates, etc? I going to tub the back and run 17x8 rims and 245 to 255 tires? I 'm also going to run a turbo 914 or older 911 Porsche motor!
Old April 15th 2008, 20:30
effvee effvee is offline
Wider tires?
Hi, going wider tires for a IRS is not that big of a problem. If you are willing to shorten the axel, then why not use wider fender? I will be running 10 rims by using wider fenders. If its just to get the tires under the fenders, use wider ones. These are 10 cookie cutter;
See they fit, with three inch wider Fiber glass fenders.
You can also shorten you trailing arm by 1" per side, and a 8 inch rim will fit within stock fenders. I did a set of trailing arm myself, but have not needed them yet.
Old April 15th 2008, 22:12
DORIGTT's Avatar
DORIGTT DORIGTT is offline
Where did 10" cookie cutters come from?
Old April 16th 2008, 10:14
10 Cookies
Hello, the cookies were 6". But there is a person here in Southern California, that mods, welds, and repair Alum rims. He lathed out the center section of the cookies cutters, added a 10" blank. From the out side you can't tell anything was done. On the inside there is a complete automated weld, very professionally done.
Old April 16th 2008, 18:51
DORIGTT's Avatar
And that person/shop would be....?
Old April 17th 2008, 11:46
/shop
O silly me, sorry about that:
The name of the business is, Eric Vaughn Wheels.
Number: (626) 358-6413
Also I just called to make sure the number is still good and it is.
Old April 17th 2008, 12:44
DORIGTT's Avatar
Thanks!
I'll make that call.
Old April 22nd 2008, 09:19
Bullyboy Bullyboy is offline
I am running 7" wide wheels with 225/60-15 tires with lots of room to spare under 1.1/4" widened fenders.
Old April 26th 2008, 16:27
Sunroof53's Avatar
Sunroof53 Sunroof53 is offline
This is how i did mine .Limitation is spring plate clearance.
http://www.germanlook.com/Html/Tech/...ingIRSArms.htm
The wisest mind has something yet to learn
