Old April 24th 2008, 00:40
vwcossie vwcossie is offline
VW 1303 Cosworth
I have for years planed this car, but it is not possible to get road legal in Norway cause strict and stupid regulations.
Car: VW 1303 -75
Engine. Ford Sierra Cosworth 220 bhp/214 ib/ft (Stock) Easely tuned to 300+
Transmission: VW 091 with ZF lsd. Ratio adapted for engine, weight og car, wheelsize etc. For max performance. IRS bus to sedan intermediate housing.
Brakes front: 330X32 from VW Toareg. Brembo 4 pot from Mitsubishi EVO 8
Brakes rear: 330X28 from VW Toareg. Brembo 4 pot fom Fiat Coupe 2.0 20V Turbo + Brembo handbrakecalippers from Aston Martin DB9.
Suspension: Bilstein coilovers front and rear.
The car was planed use for street legal dragracing, trackdays etc.
It would be build with show finish.
Wheels: 7X17
Other: Full rollcage, radiator and batteri in front, watercooled intercooler.
Check out my restoration project: http://www.vwnorge.no/index.php/topic,367.0.html
Old April 24th 2008, 00:56
KEP adapterplate with flywheel after my own spec.
Transmission moved 80 mm into the car for bether traction on clearance to rear lid.
Old April 24th 2008, 01:09
Using the hub from 1303 with drums You can bolt on a custom bracket made of aircraft quality aluminium.
It was possible to use 345 mm disc with these calippers and 17" rims,
but i didn't find reardisc to match to get the right front-rear ratio that I needed.
Calippers, acryl-prototype bracet and drawing for sale.
Old April 24th 2008, 02:50
Looks like an interesting project. I live in a nanna (grandma) state as well. But we are allowed to fit a turbo motor 2.5 x the stock factory car weight = 2175 cc or 3 x for a NA motor = 2610 cc.
Is it possible to have the car road legal in another country but still use it in Norway?
Old April 24th 2008, 03:15
I assume if I got the car tested and approved at TUV in Germany.
But I think that will be very expensive.
Old April 24th 2008, 16:11
Looks great, keep us posted on the build. Lots of pics!!!
Old April 24th 2008, 16:40
Timmy_Barns's Avatar
Timmy_Barns Timmy_Barns is offline
Interesting swap.
I had a question, but then I realized you already answered it in you're first post.
99 Mk3 Jetta
Don't take life seriously because you can't come out of it alive" --Warren Miller
