Old August 14th 2006, 10:59
kitchenware's Avatar
kitchenware kitchenware is offline
Originally Posted by vw1303
The rear wiper from a mkII golf works perfectly on a 1303. I made new mounts for the scricco motor and it works awesome.
How's the wiper contact with the glass? Is it raised on the edges or do you have full contact?
Old August 18th 2006, 18:46
juse's Avatar
juse juse is offline
Originally Posted by juse
A Scirocco windshield wiper motor is not that easy to find...Does any other VW share the same part? Or which would be the next best alternative??
Justin
Well I`m not after a single blade wiper...just a more modern motor for my super. So is there any VW part for a straight replacement?
Justin
RedHotPapaBastardizing
Old August 20th 2006, 15:01
oasis's Avatar
oasis oasis is offline
I think I know what you are asking. The stock wipers of a 1303 generally don't maintain contact at the windshield's bend.
The single-wiper conversions I have seen look like they go bend-to-bend. So, yes, they maintain contact with the glass but, no, they don't swipe the area of the bend either. In fact, it looked to me if the wiper was extended to include that area on either side, the wiper blade would extend beyond the top of the glass when the wiper would point at 12 o'clock.
Old August 20th 2006, 16:43
Justin
I think they mount up the same, but the plug would be different. I'll try the mk3 motor on my stock 1303 assy later today.
Old September 1st 2008, 05:22
BulletBug BulletBug is offline
anybody here done conversion using jap parts... i have honda prelude single wiper in mind... can it work??
Old September 22nd 2008, 07:04
Joel's Avatar
Joel Joel is offline
geez bullet bug ur grave digging every thread from the vault LOL
i had a single wiper conversion for a while
i just cut down a flat screen beetle wiper motor so it was only one shaft and mounted it to the LHD mounting hole in the center with a stock 1303 wiper just with the bend straightened out
i also changed the arm arrangement so it parked in the vertical position
it gave great coverage but i had to return it to stock to keep the local authorities happy
Old September 30th 2008, 03:43
grave digging?? u mean that im using jap stuff?? i dont have any scirocco in my country... any other options??
Old September 30th 2008, 04:47
Joel's Avatar
nah by grave diggin i just mean replying to posts that are over 2 years old
Old October 5th 2008, 18:45
Angelo Amato's Avatar
wipers
single wipers suck !
Type 3 Fastback
Old October 6th 2008, 01:26
any alternative?? common guys... my friend used a back screen wiper from lancers... quiet ok la...
Old October 7th 2008, 19:47
I'm going to stick with dual wipers as the engineer that has to pass my car has said that the duals have to stay.
What I'm thinking of doing is altering the pivot ratio on the passengers side of the car so that it does a longer sweep, this is on a 1303.
Old October 12th 2008, 07:16
Joel's Avatar
Steve, thats what i did when i had the single wiper to get to cover the whole screen
i chopped 5mm out of the spindle crank
