Old November 5th 2008, 03:29
kuna's Avatar
kuna kuna is offline
1303 dash - say what you think
Hi,
Home made dash mod for 1303 beetle. Set of early 944 gauges + 3 VDO. All switches relocated (ashtray and speaker area), ventilation&heating 1303 stock and working (this was the hardest task). Dash is coverd with FLOCK, the same material is used in racing cars
work in progress.
incomming:
- electric opening for front hood
- hand brake warning light instalation
BTW does anybody know if its possible to make 944 fuel gauge work with 1303 sender (with fuel reserve light)?
Old November 5th 2008, 13:31
Pics aren't working...
owdlvr's Avatar
owdlvr owdlvr is offline
photos?
'71 Type 1 - Rally Project
'75 Type 1 - Family Heirloom
Old November 5th 2008, 14:24
Jim's Avatar
Jim Jim is offline
we can't see the photos mate...
http://www.bugaru.gr
EJ20 Suby Naturally Aspirated
Old November 5th 2008, 17:06
Flocking looks good!
I pasted the pic links into the browser to see them, then they appeared in the message, odd!
Re: sender, you could probably just fit the Porsche sender in your tank...
Old November 6th 2008, 00:16
randyj randyj is offline
Kuna,
I followed Ricola's advice and was able to view your pictures. I right-clicked on the picture frame and then selected properties. I then pasted the address into another browser page.
Your dash looks great!
How did you build up the area for the 944 gauges?
Do you have any pictures of the making of he dash?
Randy
Old November 6th 2008, 03:21
Jim's Avatar
Jim Jim is offline
Awesome dude!!!
Any other side of view of the dash?
Old November 6th 2008, 10:47
oasis's Avatar
oasis oasis is offline
I, too, think results are outstanding. I, too, am very interested in these answers ...
(2004-2008): 1971 1302 w/2056
Old November 6th 2008, 10:58
helowrench helowrench is offline
very nice,
I have a parts car (924) coming a month or two from now, and I plan on using the instruments in my ghia. It is nice to see that somen=one else has done this.
Were there any particular areas that you had trouble with?
Rob
Old November 7th 2008, 09:05
kuna's Avatar
link to my picassa album with photos, I have no idea why they aren't working.
http://picasaweb.google.pl/krzysiek.kunicki/Garb#
It's std 1303 dashboard, I have cut out the orginal speedo area and created aluminium construction that holds 944 gauge mounting plate, after that everything was sprayed with foam ("growing" building foam, used for ex. to mount windows,doors) whitch was shaped (or rather sculpted ) to reach the final shape, in the end all was coverd with glassfiber and putty finished.
Porsche sender won't work.... it's hmmm... tube-like, not floating
I will look for some photos I made earler with my cell-phone, but their quality won't be cool.
It's nice to read those all positive comments thanks!!
If you have any more questions just ask
Best regards.
Old November 7th 2008, 09:55
evilC's Avatar
evilC evilC is offline
Nice job!
evilC
Old November 7th 2008, 12:26
I've seen a Porsche sender used in a standard bug before, the bolt pattern was near enough the same, just had to make up a spacer (about 2") so the tube sender doesn't sit on the bottom of the tank...
Old November 7th 2008, 13:53
how long does the sender need to be. a ghia sender may work, and they are the tube type.
(I have a spare that I can measure to compare)
Also, plug in your lever type sender to see if it works. You never know unless you try.
Rob
Old November 7th 2008, 18:23
Beautiful integration!
Old November 11th 2008, 15:40
kuna's Avatar
http://picasaweb.google.pl/krzysiek.kunicki/Dashboard#
3 photos, 1 early stage (aluminium construction), 2 foam shape done.
