Old September 9th 2009, 11:47
Laser cut brackets
Its a long time since any progress on my car while being busy with the new purchase which just stormed through the MOT with the only serious thing being a rear brake hose corroded.
These arrived in the post yesterday :
Laser cutting is fantastic and was cheap here and the turn around time from diagram to delivery was only a couple of days too. DC developments in Norwich did them for all you UK people.
So finally I have all the components to get the brakes mocked up for hoses and lines.
The actual build is still a way off should go together like an Air-fix kit when the time actually comes but plans are constantly hatching and evolving.
Old September 9th 2009, 23:16
johnnyvee's Avatar
johnnyvee johnnyvee is offline
don't think that the pic could get any bigger
Old September 10th 2009, 06:45
How much is cheap?
Old September 11th 2009, 07:21
evilC's Avatar
evilC evilC is offline
Al, I presume we are looking at some caliper conversion brackets? If so, the size would imply they are for a Volvo Truck!!
What brake set up are you contemplating?
Old September 15th 2009, 01:53
Apologies about the pic size again!
Clive: Brackets are the fronts to go with hub machining I had done ages ago on drum spindles. >85 944 NA brakes all around, have a stanadard MC and a 944 tapered one to have a look at for when I get around to it. Though I keep thinking a balance bar and hydraulic clutch would be nice to have...
Rich: A shade under £50 delivered and it took less than a week from posting a cheque to receiving the parts.
Old September 15th 2009, 06:40
henke henke is offline
Do you wish to share those CAD-files?
Old September 15th 2009, 08:42
All freely available on the net/many books. I'll sort out some diagrams hopefully later today along with the rest of the brake build.
Al
Old September 15th 2009, 09:04
Old September 15th 2009, 13:31
A how to I posted a while back on VZi...
Pre 85 944 N/A hubs, modified for beetle spindles. These use standard beetle bearings but a thinner grease seal, available from most bearing places.
Spot faced stock drum spindles. This is important, others ARE different. Be aware. There is loads of alternative methods on GermanLook.
And the front machining
Fitted with bearing adapters
Machining Diagrams:
BEETLE spindle, PORSCHE hub stock (all from Ricola's website)
Bearing adapters
PORSCHE hub mods
Caliper adapter plate - wider holes are tapped M12x1.50
Old September 15th 2009, 13:43
Unfortunately the backing plates rub on the discs so I will be taking these off. I suppose they could be modified but I'll have to look into it at a later point in time
Also if anyone has some three hole rear >85 NA backing plates I'm after some
Old September 16th 2009, 07:11
Perfect!
Thank you very much
