Old August 9th 2009, 15:13
Looking very nice. I too love the balance of the exposed CF touches.
Old August 9th 2009, 18:43
kafercup kafercup is offline
Side scoops
Are those the Remmelle side scoops? Did you lip the quarter panels and set the scoops in (so they sit flush), or are they glued on top of the quarter panel with just the hole cut for the duct?
I have the same scoops and am trying to figure how I want to mount mine.
BTW, beautiful car!
Old August 22nd 2009, 16:00
updates??
Old August 23rd 2009, 00:53
petevw's Avatar
petevw petevw is offline
Wow nice ride. I had missed it
'72 super
'65 bus
'52 split
Old September 18th 2009, 15:29
tom'72's Avatar
tom'72 tom'72 is offline
Originally Posted by kafercup View Post
updates??
Haven't had much time to work on it lately but had a few problems.
First the engine wouldn't fire, turned out the crank sensro wasn't sending a signal to the ECU. Ordered a new crank sensor but it still wouldn't fire.
Will have to check each wire, ground and connector for any faults.
Old September 18th 2009, 16:15
Can you give me some details on how you went about installing the side scoops?
Old September 19th 2009, 07:46
tom'72's Avatar
I first made a cardboard template of the scoops shape and then made that about 1cm smaller all around.
Then I positioned that template on the body and cut it out ( this hole is now 1 cm smaller all around then the outer dimensions of the scoop.
Then I used a special type of pliers (have no idea how it's called in English) to make the body pannel where the scoop will be glued over fall just a bit deeper (think its 2mm) then the rest of the pannel so the scoop sits flush in the body.
You can see how the edge where the scoop will be lies a bit deeper here.
Old September 19th 2009, 07:49
tom'72's Avatar
The scoops are glued in place and I used a black sealent (looks and feels like silicone) to finish the outer edge ( am going to do that again as my first attempt wasn't as good as it should be).
Old September 21st 2009, 11:41
The rear wheels out alittle would be nice
T4 2666 1303s
Old October 2nd 2009, 14:48
tom'72's Avatar
http://www.youtube.com/watch?v=0XH4vFT4AX8
Hopefullly will be able to finish up suspension, gears, clutch and gas cable + lots of other bits that need tidying op over the next week or so and then take it for a test drive
Old October 2nd 2009, 20:11
excello excello is offline
WOW
That made the hair in my nek stand up. Nice!!!!
http://1302rs.blogspot.com/
