Old October 3rd 2009, 07:36
buggyboyshane buggyboyshane is offline
Originally Posted by chug_A_bug View Post
hey... if you are using a T1 then you Need a 200mm flywheel and a autostick/bus Starter and you are going to have to take out the Stud that holds the starter and shave
about 5mm off, then everything Should work. hope that helps
brilliant!!!
gotit started!!! wooooooooohooooooooo!!!
using a 914/ t25 auto starter......... works a treat!!
ok........... next problem........
i have stock beetle clutch cable with special ends for porsche throw out arm.
when i press clutch, the arm is pulling underneath ok to throw out the bearing but only moves slightly before hitting gearbox case underneath.
it seems to me like i should maybe have a spacer behind the throw out arm, means the release bearing would be closer to the clutch and the arm could travel more underneath........ or else slightly bend the arm, but worried about that one!!
any ideas??
Old October 3rd 2009, 13:29
vdubzack's Avatar
vdubzack vdubzack is offline
Originally Posted by buggyboyshane View Post
brilliant!!!
any ideas??
Check this thread, and get in touch with them. Thats what I did
http://www.germanlook.net/forums/showthread.php?t=9153
Old October 14th 2009, 16:24
jmd's Avatar
jmd jmd is offline
I hear that the solution to this is to bend the arm. But I am using the 901, with a (Currently) stock cable and it works fine. But I am about to convert all that to a custom pendulum pedal setup so my configuration will change.
Old October 14th 2009, 17:06
i was using 901 one and needed to bend the arm and grind some of the hook away to let it slide past the frame horn, all worked perfect!!
