#151
If the photo was taken 10m further on the the arrow would be pointing at the car!! (shame, you'll have to come back and do it again!) but its still a great photo.
Clive |
#152
Haha, kind of like this.....
![]() Looks like you're having a lot of fun with your car.
http://1302rs.blogspot.com/ |
#153
Exactly like that! Brilliant!! (I have noticed that the Dutch are travelling on the wrong side of the road{again}! lol I must try that when I'm next in Holland - oops)
Clive |
#154
Excellent dude! Thanks, its very well done. Amazing!
I hope you will be carefull Clive ![]() but you know what they say: when in Rome.... ;-) Last edited by Wally; September 9th 2009 at 13:05. |
#155
Got a smoking deal on a slightly used 'bigger turbo'
![]() Hope it gets here in one piece soon... Its not one of the usual turbo's that are being used though.. ![]()
#156
Don't you have a bigger picture
![]() Paul:
#157
Judging by the size of that picture, it IS a big turbo !
GT3076R CHRA ? ![]() When is it being installed and when is the dyno booked ? ![]() Sandeep |
#158
Yep, I guess I have basically the same turbo as you then?
![]() Quote:
#159
The Blouch DOM3 (or GT30R if you like) is underway and going very well. Almost too well...
Getting the right orientation for the install under the bug meant disassembly. Always scary as you don't know the part and taken apart a perfectly fine almost new part is somewhat counterintuitive..(well... ![]() )![]() ![]() ![]() Here you can see that the intake is just passing the cupstrebe and the tranny/starter. The wastegate even has more room on this one, but one of the alu threads for fixating it to the housing is almost stripped...Have to wait and see if it holds. ![]() So, the IHI VF34 is now for sale ;-) Last edited by Wally; October 11th 2009 at 15:40. |
#160
Nice find, I see lots of power in your future!!! How do you think this one will stack up against your current one for lag?
#161
Its a 2.2L it should be pretty wicked, I'm guessing 3K to 3500 for spool start time... I think a GT30R has ball bearings...
Everyone told me its not a good idea to daily drive an aircooled bug. I agree, if the engine has a distributor and you use cheap engine parts... OR you have an early car without the decklid vents or you neglect to add an oil cooler with fan... |
#162
Kulein: the former IHI VF34 had ball bearings also! Theoretically spool should be (much) later, but in reality I think it will not make that much of a difference. A little later spool is not neccessarily a bad thing! I actually like spool to be a little later so your not on (back)pressure all the time on the highway and overall back pressure (=high EGT) is less. About 1 bar boost (14.5 psi) at 3800-ish rpm would be excellent for me. Right now I had 1 bar at 3300/3400 rpm in 4th. The old turbo had a nicer (for me personally that is) spool on the 2 liter. Purely track driving, spool of the VF34 was better on the 2,2 I think. In 3rd coming out of a corner at 3000-3200 rpm, spool came in really nicely an drelatively gentle. That last thing is cam and tune (wastegate ecu control) dependant as well of course. |
#163
Waste gate location
Hi Walter, please be very careful of the waste gate location. If somethng hit it/bend it, you could over boost.
#164
I think a lot of people use the GT30Rs here for 2.0 - 2.2L engines, with good results, but these aren't Aircooled VW engines, so who knows...
#165
. You could kill two birds with a heat/impact shield over the waste gate and exhaust side of the turbo.Clive |
| Currently Active Users Viewing This Thread: 17 (0 members and 17 guests) | |
