Old November 13th 2009, 17:51
vwbao vwbao is offline
rack and pinion for 74sb
hiI have a question about installing a rack and pinion to non rack and pinion super beetle, what else do I need? I have the rack and pinion with mounts from sb 1975, do I nee to change my steering column/copler or other else?
thank you.
derek
Old November 18th 2009, 07:37
Joel's Avatar
Joel Joel is offline
the steering shaft with universals is a different lenght so you will need it as well
ive got it all sitting here waiting to go in mine, just been putting if off as the frame head needs clearancing a bit under the wheel well
Old November 18th 2009, 17:35
This is what the chassis looks like underneath. The chassis clearancing would be the biggest headache, maybe weld in a 1/2 tube. I've only done it on a 1302 and it needed a lot of work, maybe the later bugs don't need as much.
Old November 26th 2009, 00:02
hi, do you think with the 74 model will only need the frame head cut and none on the spare tire well?
Old November 26th 2009, 00:15
is this the 75 model or the pre 75?thanks
Old November 26th 2009, 00:25
The photos is from a 75 I wrecked, it had the rack & pinion that Joel has now.
Old November 26th 2009, 00:40
do you have a picture of the frame heat of the 75?
Old November 26th 2009, 03:27
I will did it out from where its stored at the side of garage and take some photos.
Old November 26th 2009, 14:49
Thanks mate!
