Old November 22nd 2009, 10:16
Iīm sure it wonīt take long before become that nutty aslo
Old November 22nd 2009, 12:59
I wanted a cam slightly more agressive than the 119 without losing idle quality.Iīm hoping it will be a bit more snappy and faster on spool up.My original choice was the 163 but the 86a runs much smoother and I believe it is a better cam for a 2 liter. .
Just checked webcamshafts website and I think the valve lift of the 86a is too small (11.05mm). Turbo's love valve lift is my current experience.
There's probably a reason Webcam advertises their 119 as a turbo cam...
I would advise to change the cam to one with about half an inch lift (12,7mm)
1.7mm lift difference is A LOT!
Just my 0.02 cents worth of friendly advise
Old November 22nd 2009, 15:15
Youīre right about turbos loving high lift,I might trade it in for my original choice the webcam 163.I havenīt really decided yet.I like the 86a because itīs a "quiet" cam and easy on the valve train and still pull to 7K.As you know choosing the right cam is always a challenge.What doesnīt make it any easier is following your experiences and seeing and driving with Arminīs 2 liter turbo with a low (11 mm) cam and the performance that his engine has.Itīs actually not that spectacular riding in Arminīs turbo and you think at first itīs kind of a pooch,then you glance over at the speedo and youīre doing 260K/mh.His car doesnīt have the snap or agressivenesse that we see with the type 1s i.e. 2276 or so.But itīs just incredibly fast.Itīs a ticket magnet...
Old November 22nd 2009, 15:48
Well, your the builder, you must choose eventually
Old December 15th 2009, 05:51
A very small update: The CU heads are back from glasbead blasting.To my surprise,they are in much better shape than I thought! Today they are getting shipped off for porting,seats,valves etc.
Old December 18th 2009, 05:51
Another small update.The case work is finished.The mains had to spindled out to 0.50mm.Now I will clean the case up a little better and then install the Raceware headstuds.
Old December 18th 2009, 05:59
Good progress!
What are those weird looking copper-coloured thingys sticking out from under the bores?
Old December 18th 2009, 06:04
Good progress!
Oil squirters to cool the pistons.Simple but effective
Old December 18th 2009, 08:14
Thought so, but how are those fixated? Mine sit much higer up and into the bearing saddle.
Old December 19th 2009, 07:28
The saddle is tapped and the squirters are screwed in.The squirters are the tips from a wire welder.Iīve seen others use grease nipples/fittings aswell.
Old December 19th 2009, 07:45
Xellex's Avatar
Xellex Xellex is offline
guys, what size do you think is best for the hole in the squirters? And do you have a closer look picture of them?
www.vw1303s.com
Old December 19th 2009, 11:27
There are different options.My case uses the tips from a wire welder with an M5 thread.Location and angle are the key to make it work properly,though.
Old December 19th 2009, 15:05
Xellex,
I use the squirters from a 911 turbo. Those also have a check valve inside so your oil pressure doesn't drop at (hot) idle. They open at 2 bar or there about
Mark,
Did Remmele install these for you?
Tnx,
Walter
Old December 20th 2009, 08:20
Mark,
No, Remmele uses the Porsche squirters also IIRC Most of his engines do not have oil squirters.Armin did the casework - itīs one of his cases I bought from him.I gave him my case as a "trade in".So he deserves the merit on this
Old January 25th 2010, 06:02
Another small update - my billet single stage dry sump pump from Thorsten Pieper came in.It has a 3 piece housing with 32mm gears.
