Old January 4th 2010, 21:30
I'm sure you haven't but don't forget the crush tubes... Nice to see it done with the side piece at an angle, most others I've seen do it vertically, must be a pain for the body seal!
Quit rushing me...I do have 1/2" dia. SS tubing for crush tubes
Getting a good seal on the pan gasket is one reason for the angle. This is about the best you can get given the distance from point A to point B
I was hoping to post the finished mounting, but didn't have a 1 5/8" hole saw for the boot, and rod to go through (got 1 1/2", and 1 3/4" hole saw though ) Guess I'll bring one home from work tomorrow...
Old January 5th 2010, 20:37
OK. I brought home a hole saw, and finished the mounting holes. Next is matching what I did here to the firewall on the body. I need to get the pan back on the body to put mock-up motor back in for building a header. Because, coming up real soon, I get to build my motor, and dyno it, but i can't do that without a header. So, pedals and slave cylinder mounting has to wait.
Old January 6th 2010, 16:15
jmd's Avatar
jmd jmd is offline
man that shift linkage solution is awesome. i have been inspired in my own solution. thanks for blazing new paths!
Old January 6th 2010, 20:47
Thanx man. I thought all the people thinking about doing (or have done) a 901, 915, or G50 would like this idea...it's just taken ALOT longer to get to do it, because of everything else that gets thrown my way for help.
Old March 1st 2010, 16:59
dub_crazee's Avatar
i agree with the above dude- its a great solution - im hoping to do something similar in the coming few weeks
out of interest how are you going to be mounting your clutch slave cylinder to the clutch lever arm?
Classic Car Revivals
www.classiccarrevivals.com
Old March 1st 2010, 22:08
I haven't had time the last month or so to get back on my project. In the coming weeks I will have time again, and will do that part of the conversion. It will be easier to show pix of it then to explain it in words though.
Old March 7th 2010, 15:14
dub_crazee's Avatar
haha no worries - you sound very busy!
il be jumping back on my chassis this week too - finish getting the gearbox mounted and the tunnel mods done - fit fuel lines and 5 bar kafer set up in! busy busy!
Old March 7th 2010, 21:39
Well, I just finished my friends motor rebuild and he will pick it up tomorrow afternoon Then, I can get back to the important stuff . This weekend is the first VW event I attend every year (SEVWA Dyno day sat. and, show/drag on sun.) so, will not make any head way this weekend, but I may find a few more parts for the project though
Old December 14th 2010, 18:07
Xellex's Avatar
Xellex Xellex is offline
any news on this? I'm right behind you with the 915 install, and your topic, amongst a few others here are always inspiration to me!
www.vw1303s.com
Old December 15th 2010, 16:55
No progress on this part of the build. Got my motor built, and switched back to making my header so I can dyno it. This past year has not allowed alot of time for my (VW) projects.
