Old February 24th 2010, 23:57
Humble's Avatar
Humble Humble is offline
300# will be pretty damn close based on Clive's calculation, depending on rear axle weight you might go as high as 350-375
Old February 25th 2010, 05:35
evilC's Avatar
evilC evilC is offline
Hi Sandeep,
Why not junk the bump stop on the trailing arm and fit one on the damper? That'll have two effects:
1) The bump stop then relates specifically to the damper as it should without relying on a remote location and possible miscalculation (and zip ties!).
2) The bump stop would act as a cleaner/scrapper on the damper rod adding to the cleaning seals and minimising the possibility of ingesting dirt.
QA should be able to recommend some bumpstops.
Old February 26th 2010, 16:20
Humble's Avatar
For bumpstops go with the vw/audi marshmellow bumpstops. they are a favorite of racers because of their progressive nature. You can trip them down as needed.
Old February 26th 2010, 18:48
petevw's Avatar
petevw petevw is offline
Do you have a part number? Source at the dealer?
thanks
'72 super
'65 bus
'52 split
Old May 31st 2010, 15:37
Eatoniashoprat's Avatar
Sandeep, could you share which springs you ended up using? Length and lbs/inch? Thanks
Mike
1302 EJ20 turbo
