Dave Forder's new GL bug
Saw his new chassis at the volksworld show today. It is the ex John Maher project that he has had Mark Dryden from flatlands engineering redo. Seems like a pretty decent spec...
Enjoy the pics!
http://www.ricola.co.uk Last edited by ricola; March 27th 2010 at 18:15. |
few more pics...
http://www.ricola.co.uk |
Very nice.
nice but im not a fan of the shifter up that high looks outta place
YEAH ITS GOT A HEMI |
i kinda like the shifter placement. you can keep your center of gravity lower with your seat position being lower, and the shifter will be right in arms reach.
The really strange thing was that whoever put it together has put a single circuit brake master cylinder in and even got the brake and clutch cylinders on the wrong way round (ie left pedal is brake!)
Is it Legal to have you pedals round the wrong way ????
Whats that bar justinfront of the rear ARB, looks like its attached to the torsion tube, i noticed he is using Heim joints as well ![]()
Thanks for the pics, really nice chassis.
Sandeep |
He's definitely off to a good start, is there any other build information out there?
That bar is the front trans mount. I'm sure (hope anyway!) that the m/c thing was a silly mistake... No other build info other than the fact it will be a Remmele inspired car with a 2332 turbo engine... The shifter is a Hargett aftermarket Porsche one for the 915.
Pretty sweet the set of diagonals running to the ends of the horns from under the torsion tube.
Like another set of 'kafer bars' underneath. Gotta dig the mounting of that 915. Middle of the trans with that plate, and at the nose, too, right? That's what that smaller tube running under the torsion tube is for? Might be the most stoutly rubber mounted transaxle i've ever seen. Without using the body as an anchor point. Anybody else get the hump from seeing engine mounts that tie into the body sheetmetal? I know it works, but... |
90% of the engineering for this pan is my work!!, i did this 5 years ago! and was never ment to be a show car!!!!! it was designed to be a daily drive that could beat an M3 on the street. there are some nice tricks in the front beam and rear suspention
![]() thanks Marco Mansi.... MMP |
Hey Marco, who did you do the work for? Got a new project you can share? I remember the project you told me about at volksworld a couple of years ago...
Rich
Very nice indeed!
I really dig the additional self-made trans mount in the middle. Thanks for posting Rich! |
i did the work for dave forder 5years ago, ts was no way to the show standard it is today, thats all marks work, hes very very good at the detailing, he made the mid mount for the gearbox, but for me its not needed, the front mount was made to handle all the power while still rubber mounted, to soften the vibration throu the pan, The bars that go under the irs arms from the end of the frame forks to the torsion tube, realy helps with a heavy engine when cornering!, the engine in my car with the 8in tarmac rally slicks on would corner almost 1g and the engine would move 1cm in that direction, these elimanated the problem., the front beam has my special barrings in that allows them to be compleatly independent with no horizontal movement and no wear!!!! (unlike the red9design).
if you have any Q i will be happy to answer them ![]() thanlks marco mansi....MMP |
