Old December 30th 2010, 17:40
Frix's Avatar
Frix Frix is offline
Impressive, as always! How will you route the oil return line, with the turbo that low?
Old December 30th 2010, 18:10
Welcome to the board Frix!
Oil return will run as it was before with the former turbo as its about as high or low as the other one was
Old December 31st 2010, 11:53
Looks great Walter !
Well thought out, and looks like the turbo was meant to fit there.
Did you end up revising the down strut / cup brace ?
Old December 31st 2010, 12:08
Thanks; well, I have removed it for now as it didn't fit at all anymore with the air intake in the way. I have not come up with another alternative then brace it through the firewall onto a cage support point in the rear...
Oh well, first have to finanlize the install completely with WG before I do anything drastic.
I also wanted to redo the piece of 2" pipe just after the intercooler (2,5" exit) and the T-split. The individual 2" pieces to the pressure hats can easily remain 2" imo, but making the intermediate bend from 2,5" just seems more logical:
Old January 7th 2011, 12:59
Steve Arndt Steve Arndt is offline
Wally,
Check this divided housing fabrication.
http://www.honda-tech.com/showthread.php?t=2880250
Steve Arndt
Old January 7th 2011, 15:11
Originally Posted by Steve Arndt View Post
Wally,
Wicked nice welding for sure! Subies/Evo's and Honda's use the twin-scroll set-up a lot.
You're reading ricer forums now?
j/k its a good thing to broadthen (sp?) our minds and apply new (although usually very old) tech to our engines/cars ;-)
Old January 11th 2011, 01:25
KAFUR1's Avatar
KAFUR1 KAFUR1 is offline
Originally Posted by NO_H2O View Post
Looks to be smooth at 137. I might just have to cut one out for my car.
You too!
Old January 12th 2011, 04:46
...always know what you´re enemy is doing...
Old January 12th 2011, 11:16
MX67 MX67 is offline
I agree!
Walter, what's with Your 1200 turbo engine and will you have thread here on GL forums about build? That downsizing stuff is very popular now
1967 Bug
Old January 12th 2011, 15:57
I dunno if that would be a good idea, its not really in the spirit of max performance, though I am very exited about the project it myself tbh . Its slow progress too as it all costs still a lot, even if its type 1.
Meanwhile, some progress on installing/trial fitting the Tial wastegate, trying to outsmart the system by just using one WG by dividing the uppipe
Divided pipe is now visible, of course needs to be shortenend and connected to both up pipes to turbine.
New wider pipe to the intercooler fits well too now, almost straight shot from the turbo
Old January 13th 2011, 06:37
Looks like it´s getting tight in there now I suppose there´s no way of locating the WG further upstream?
Old January 13th 2011, 07:40
Just for the WG there would be room upstream just under the rear valence right after the 4-2 sections, but I saw no routing of the neccesary slicencer anymore then.
Old January 13th 2011, 15:57
Getting close. I look forward to some new videos.
Old January 13th 2011, 16:56
Yeah, coming saturday I hope to get the oil return outlet for the turbo and have the flange machined flat again as it has warped a bit after my welding...
Still the main downpipe silencer is not here yet and that needs lots of modifying too. Lots of work still.
Old January 15th 2011, 16:18
Flange machined flat again after it warped after welding and the neat oil return flange:
Currently Active Users Viewing This Thread: 10 (0 members and 10 guests)
