#646
Speaking of oil feed tube...
Wally, sorry if you've put that info somewhere, but which oil do you use in your engine? I'm asking because there's much debate going on about zinc levels in modern oils. I'm reading some ricer forums and they're speaking about Brad Penn grade 1 20w50 as the best choice. Jake Raby also prefers that oil. Maybe we should make "oil thread" on GL...
1967 Bug |
#647
But please not another oil thread... enough of those already. |
#648
Hi Walter,
I noticed a fitting on your sump extension ... I know which DS pump you are running so am guessing that this is the return for your turbo ? If not, what is it for ? Are you still using the Tilton scavenging pump ?I'm trying to eliminate as many support systems as I can in my build right now, and this looks like a great solution for the turbo drain ... considering the 38mm scavenge circuit in the DS pump. Unfortunately, I also have to upgrade the DS pump feed from a -8AN (12.7mm ID) to either a -10 (.625" / ~15.9mm ID) or even a -12 (.69" / ~ 17.5mm ID). More fittings .... more hose ![]() Sandeep |
#649
Of course
![]() Its a -12 hose I use, same as I use for DS pump feed from the front trunk. Better safe then sorry. I bought the Tilton, but have still never even used it... ![]() Just today I did some work making the wastegate feed tubes from both pipes and still keeping them separate. Hope to have some updates at the weekend. Last edited by Wally; January 22nd 2011 at 13:48. |
#650
Very happy with the progress from today.
![]() ![]() ![]() Only downpipe + silencer to sort, but the silencer from ebay still needs to arrive... |
#651
excuse me if I got it wrong, but is the waste-gate gonna have it's own silencer to the left, and the main silencer is going in the old position? Couldnt the WG dump in the same exhaust pipe?
www.vw1303s.com |
#652
Its also better to keep it seperate for the least possible backpressure in the downpipe. Lastly, there was probaby going to be possible ground clearence problems routing it back into the downpipe exhaust. |
#653
#654
Oh! hell the beast is back. More vids wally. Ah! just a question, how much horsepower do you intend to make this time?
#655
Nice job Wally! I´m anxiuos to see what it does on the track and dyno!
#656
Very nice Wally!
#657
looking/sounding good
#658
Good to se that she has a pulse once again. Nice work.
#659
Tnx guys! Just a new lambda bung and the big turbo silencer and I can drive again
![]() Quote:
![]() Interesting will also be how the heavier CB 650 valvesprings will go along with my stock 'non-straight-cut' cam gear and stock single thrust cam bearing... |
#660
Do you have a spring scale? I am interested in your old and new spring data. (install height, poundage)
Steve Arndt |
| Currently Active Users Viewing This Thread: 16 (0 members and 16 guests) | |
