Old January 11th 2011, 14:28
Eatoniashoprat's Avatar
Here are some pics from before paint. It might not be a problem for you, but I just bring it up because the ducting concerns are ones I found when researching the rad ducting for the beetle and for my bus, and so far mine have worked. In short, just make sure the air can get out easily.
1302 EJ20 turbo
Old January 24th 2011, 13:35
vw1303's Avatar
vw1303 vw1303 is offline
I have nearly my entire spare well cut out so I think there is lots of room for the hot air to go. But time will tell I guess.
A little more progress.
Got my ECU.
Starting stripping the original wiring harness. The manual from EMS is quite vague so I have alot of work to do in the wiring department.
Coolant pipes are all welded and beadrolled. I have all my clamps and hose couplers. Started laying out the fuel system. Bosch 044 being fed by a Facet low pressure pump through a surge pot and out to the injectors. I am going to mount the fuel pump at the back of the spare tire well using some leftover 2.5" silicone couplers and clamps to reduce vibration. The surge pot is going to go next to the driver side front strut.
Stage III Pressure Plate and Clutch is arriving today and so is Innovative wideband.
Old January 24th 2011, 22:53
brujo65 brujo65 is offline
send me pm I have a tune program , let me know if you need one
Old January 25th 2011, 15:20
vw1303's Avatar
Hey Brujo65. I have the standard tune that outfrontmotorsports provided. Is youR tune a different one? Also do you have a link to your build? I would like to check it out. Also anyone here wired a Stinger ecu before?
Old January 25th 2011, 17:28
I send my harness to outfront Motorsport and they make it. but I have one the lance send me. the ultimate 2.0 tune I used it on some off my customer car and work very well .
Old January 31st 2011, 11:41
vw1303's Avatar
Surge Pot/Pumps/Filter mounted. Just need some wiring and some fuel line.
3/8" Stainless fuel lines running front to back.
StageIII Pressure Plate and 6Pack clutch from Kennedy.
Im going to call outback today but does anybody have experience wiring the Stinger ECU?
Waste Spark Wiring?
Idle Control Wiring? Does this wire into one of the AUX. ouputs?
The wiring diagram is so generic the fuel injector wires are not numbered.
Old February 8th 2011, 18:03
vw1303's Avatar
Installed clutch and pressure plate. Didn't know I had to remove the donut thingy on the pressure plate so I have to pull the engine again. Installing it by yourself can be quite painful on the back
Sorry for crappy phone pictures.....
More wiring. Relays are for fuel pump and fan motors.
Organized the shop a little more. Trying to make the most out of 160 square feet.
Got a little carried away on the intake manifold. Removing bosses I wasn't using. Going to end up fully polishing it.
Old February 21st 2011, 01:52
effvee effvee is offline
Adapter
Question, will your adapter work on a SVX engine? I bought a long block bare; I needed it for mock up into my 1303. Kennedy sells one for 550 and there is another company selling one for 450, and that with a flywheel.
Old February 21st 2011, 12:25
vw1303's Avatar
effvee - Im not sure if the SVX engine will bolt to the same plate that I have. You'll want to call Kennedy for that.
Painted valve covers and intake manifold.
Chopped oil pan and pickup tube. Installed Innovative LC1.
I can almost hear it running
Old February 22nd 2011, 19:54
vw1303's Avatar
After many hours(while at work )I have finally obtained this.
I had to call Diamond Electric in Michigan. The Japanese guy who worked there had to call Japan and I now I have the wiring diagram for my ignition coil. No one new anything about this coil as it has 4 wires.
Old February 28th 2011, 14:32
vw1303's Avatar
Chopped Oil Pan.
Almost put back together. New intake and exhaust manifold gaskets. Custom Alternator belt.
Tightened up the charge piping.
Little bit more wiring, bleed the cooling and fuel system and she is ready
Old March 13th 2011, 01:59
vw1303's Avatar
It runs!!!
http://www.youtube.com/user/vw1303tu.../0/7e-MS_wMiZI
Old March 13th 2011, 02:34
Very cool! So nice to hear them start up the first time, keep us posted with the progress.
Old March 13th 2011, 06:05
Very cool. I am sure you are pumped up now.
Old March 13th 2011, 09:35
onixbonilla's Avatar
onixbonilla onixbonilla is offline
The car=$, The engine=$, The ECU=$, The work= lot of money hours.
The first time it starts= PRICELESS!!!!
Congratulations and keep coming the photos/videos!
