Old February 26th 2013, 21:24
kafercup kafercup is offline
Wtb: 1302 coil overs
Anyone here have a set of 1302 (3 bolt) coil overs they want to unload? I currently have the top line maxx setup, but they are too low even on the top setting. I'm interested in the kerscher/ Csp type setups.
As an aside, my maxx setup will be for sale. They've only been mounted up in the garage, absolutely no road time on them.
Old February 27th 2013, 00:32
cookvw's Avatar
cookvw cookvw is offline
how much higher are you wanting to go? you can buy a longer threaded body to have more adjustment, and slide that onto your strut housing. you can buy these usually from places that carry suspension components. if you need help finding a place, my friend knows of an online place that carry's them. you can use the snap ring to hold the bottom of the threaded body. it would be way cheap. proabally no more than $80.
Old February 27th 2013, 03:54
Pablo Pablo is offline
I had the same problem with my Kerschers.
You could just buy/make extensions for the strutt top.
Old February 27th 2013, 06:17
Did you have the 0-50mm or 30-80mm coils?
