Old May 18th 2013, 07:13
Due to the fact that I have to use X-joints (don't know what they're called) in the steering, the steering column had to have an extra bearing. So I made a bracket, shortend the column and mounted the bearing. I am pretty pleased with it.
Paul.
Old May 19th 2013, 04:34
Looks good.
Old May 19th 2013, 15:46
Originally Posted by NO_H2O View Post
Looks good.
Thanx.
Old May 26th 2013, 09:20
I didn't like the way the gearbox was hanging (i did this 2jrs ago) so it was time for "plan B".
"Plan B" is mounting the gearbox higher, further inwards and solid.
Back mount are ready, now it is time to do the front.
Paul.
Old May 28th 2013, 14:24
Getting closer to a roller!!!
Old May 29th 2013, 07:39
Yes, closer and closer
Old May 29th 2013, 07:40
Also made a solid mount for the clutch side.
Paul
Old June 1st 2013, 16:24
Won these today on Evilbay, Spax Coilovers.
Paul.
Old June 5th 2013, 08:17
I Wasn't happy with the first gearbox mount. So it was time for plan B. The new frame horns.
Paul.
Old June 8th 2013, 16:17
The frame-horn replacements are ready, when the body goes of I will make the def. welds.
I widened the gearbox mount, this will make it stronger and improve the looks of the roll cage.
Paul.
Old June 8th 2013, 16:22
Also made a start on the cage today. I want to be able to use the backseat. this is my try of a rollcage with a backseat.
Paul.
Old June 9th 2013, 01:51
Loving this build, keep the photos coming.
I made this reply because sometimes when you post things and you don't get a reply it seems like your talking to yourself.
I really like what you did with chassis forks.
Old June 9th 2013, 03:37
Thanks Steve. I know what you mean, but I know people are watching.
Paul.
Old June 10th 2013, 14:29
Gerrelt's Avatar
Gerrelt Gerrelt is offline
Yes, I am lurching this thread, keep up the good work!
Greetings!
________Gerrelt
________homepage:gerrelt.nl
Old June 10th 2013, 14:59
Thanks Gerrelt, I will.
